Master cylinder Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C-in-DC, Feb 14, 2023.
  1. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    An independent mechanic swindled me on a brake master cylinder replacement in 2020. He charged for full replacement but only replaced the booster pump portion with a used part with warranty that has since expired. I’ve had an abs code and warning light since then but the car has been drivable even though I could hear the booster pump every 10 seconds or so. The mechanic has since been fired from the shop. The owner apologized to me for the problem and offered to install the brake master cylinder for $300. Being tight on money now and foolish, I decided to take the diy route. Big mistake.
    Recently, I did the gen 4 into gen 3 engine swap. After getting the engine sorted out I decided to replace the master cylinder a.k.a actuator using the thinkdiag dongle myself. The results are rather odd.
    The thinkdiag scan tool was able to bleed the brakes and actuator I guess. I still had to pump the brakes to bleed each one plus the actuator. Thinkdiag deleted the memory but did not relearn anything. The abs warning lights remain.
    A new issue arose in that the brake lights are permanently on. I’ve had to remove the negative pole on the battery when it’s parked. Another extraordinary thing is the car IS braking properly.
    Thinkdiag was contacted and they gave instructions on how to reset the memory and relearn the actuator’s solenoid valve, etc. That has not worked to remedy the issue.
    There is a step in the scan tool process where the ignition has to be on but the engine not in ready mode. For some reason, the ignition button goes directly to ready when pushed without pressing the brake now.
    if I unplug the battery and start the car it goes into ignition with ready mode off. If I try anytime after that it goes directly to ready mode.
    A stealership appointment was the last option to fix the issue. The service department was unable to do anything with tech stream. They didn’t charge me for the diagnostic and politely said, “good luck,” handing me the key at the door. They wrote a report saying the install was faulty and caused everything. I asked them to perform the work and they said they didn’t want to because there are bolts and such missing from the engine swap(three are missing from the air box)
    I wonder if anyone else has had similar issues with relearning master cylinder? My only recourse now is to confirm the new part was not faulty from Toyota. No other mechanic wants to touch the car because of the swap traces.
  2. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    I might’ve put the spring on the pedal in the wrong spot or the bolt and pin in the wrong hole on the pedal arm. That would explain the brakes staying on. Codes I’m getting are with the thread.
  3. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Thinkdiag support: “
    Hello sir/madam,
    After we confirmed, your car is support. Please follow the steps: Toyota> Prius>2010>ABS(Anti-lock Braking System)/VSC(Vehicle Stability Control)/TRAC(Traction Control System)>Special Functions>Brake Pad Replacement( Operation Guide). If there still are any problems, please provide us a screenshot or an operating video, thanks. ”
    i initially thought it had to do with the scan tool but the dealership couldn’t get it to relearn even with tech stream.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,481
    6,570
    Texas Hill Country
    So where did the latest master cylinder come from? If it was new from Toyota and ordered based on the chassis vin (not the gen4 engine), Techstream should be able to set it up. If it was used or sourced from a third party, there is a good chance it is the wrong one.
    The engine codes are another story. What type of gen3 to 4 swap did you do? Did you retain the gen3 egr and intake?
    I have wondered if these gen3/4 swaps would make the result unmanageable by Toyota in the future. It sounds like your dealer is acting that way.
  5. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    It was ordered online from Toyota at a “dealer discount” because that particular dealership is pretty far away from any major cities. I confirmed it was the correct fitment prior to picking it up(2 hour drive) and it was ordered with the 2010 vin number. The dealer is blaming install for the part not working, if I was them I’d do the same. Hey the coffee was too hot, right? Put a label on the cup that says that.
    I did retain the gen 3 egr and intake. I’m still occasionally getting an evap gross leak code(major problem), egr, and cat code unrelated to the abs obviously. Seems like the catalytic converter is dirty from when the head gasket on the 2010 motor blew. A mechanic told me it’s probably a leak in the vacuum pump. I don’t know. I put cataclean in it. I’m hoping burning 30 bucks a few times will help keep it down till I can troubleshoot it more. plan on changing the gas cap since the gasket feels worn. I read threads and watched videos about smoke tests and such. Sounds like a good issue to punt to a mechanic….which I should’ve done with the master cylinder! Ah! I digress.
    Unmanageable….well, more like unmotivated. My local dealer charged me 500 bucks to diagnose the morning/cold death rattle and told me they couldn’t figure out what it was but requested another 600 to keep tinkering with the engine. Few videos on YouTube and finding Priuschat via google told me it was the head gasket Within an hour. Their rejection of the master cylinder work was a mercy.
  6. ChapmanF
    18,515
    This thread? Are other people seeing codes here that I'm not?
    I see one attached screenshot at the top, which is reporting five codes in a sort of annoying way, by showing only the fortune cookies and not the actual codes. Fortunately most of them are fortune cookies I recognize and know what codes they go with.
    The C1451 ("motor drive permission malfunction") is the one that is flat-out going to prevent you succeeding at anything else before you complete a brake bleed procedure. That's actually the purpose of that code, and it enforces its purpose without mercy. It's kept in nonvolatile memory and nothing else will clear it.
    The procedures for the other relearning steps will be available once the C1451 is gone.
  7. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    So you’re saying, if I use a scan tool following the tech stream procedure(if it has that capability) to bleed the brakes and actuator again code c1451 will clear? Safer bet take it to the dealer and ask them to do that? Then all other calibration/relearning will be able to be done?
  8. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Oops
    #8 C-in-DC, Feb 16, 2023
  9. ChapmanF
    18,515
    My run-in with C1451 got written up here. Completing the bleed procedure is what clears it.
    To be properly lawyerly about it, I should avoid guaranteeing you that other stuff will all work after the C1451 is cleared. ;)
    What I can guarantee is that stuff won't work before it is cleared.
  10. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    I hear ya. I gotta figure out the ignition on/ready off problem first to get to the bleeding. I’m wondering if the zero down or ecb invalid will scramble that. Stuck till then
  11. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Getting the following codes from abs
    c1203 ecm communication circuit
    c1345 linear solenoid valve offset learning undone
    c1392 zero point calibration of stroke sensor undone
    C1451 motor drive permission malfunction
    U0073 control module communication bus off
    0123 lost communication with yaw rate sensor module
    U0126 lost communication with steering angle sensor module
    u0124 lost communication with lateral acceleration sensor module
    u0293 lost communication with hybrid vehicle control system.
    looks like the paper clip pin jumper 4 to 13 pin made me screw things up more.
  12. ChapmanF
    18,515
    Can always clear them (or unhook the battery for a bit) and see which ones come back. The C1451 is nonvolatile so it won't go away, but if some of those U codes were flukey you might knock them off the list, anyway.
  13. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Dealer told me “ replace the brake booster, that’s one of the problems causing the codes. You need to replace both parts in tandem” He also said they would still have to trouble shoot why the brake lights stay on and the issue with communicating with the ecb. The technician vehemently stated he would not perform the bleed procedure because “it will not get rid of the c1451 code.”
    They want 2200 for labor.
  14. ChapmanF
    18,515
    That's funny. Completing the bleed procedure is the only thing that does get rid of a C1451 code, as explained in the repair manual excerpt in the post I linked to.
    I mean, replacing the brake system with one that hasn't set a C1451 code would also get rid of it. :) But of course the first thing that needs to happen after replacement is bleeding, and I wouldn't be surprised if they enforce that with a C1451 code out of the box.
  15. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    The master technician at the dealer recommended replacing the brake master cylinder and the brake booster pump thus doing what I wanted (making Toyota admit in writing the part might be faulty). Booster pump is used and under warranty so if it needs to be replaced, fine! There’s reasonable cause to ask for the warranty to be filled on the master cylinder now. Not trying to be dishonest in any way just simply asking the dealer each time to install the part again and bleed it according to the manual with tech stream.
    These guys don’t know how much I respect them for their expertise and hard work. I mentioned all the info in @ChapmanF posts. I think that pissed them off more because they think I’m telling them I know more than them or something. To be clear, I don’t! but Priuschat is a wealth of knowledge.
  16. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Is there a post with the bleeding instructions from the manual? @Mendel Leisk ? I have a feeling I did it wrong and I should just try again.
  17. ChapmanF
    18,515
    The Techstream bleed procedure, right? That one doesn't have a non-Techstream variant.
    Some procedures do. You can do the linear solenoid offset learning with a jumper. There is also a non-Techstream fluid replacement procedure, only useful when there is no air and you don't need to bleed, just change fluid.
    But for actual bleeding, it's Techstream (or another scan tool that includes the bleeding routines).
  18. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    The thinkcar thinkdiag dongle scan tool has two sections that show bleeding and ABS as well as actuator replacement. I think my error was in telling my dad how to pump the brakes. need a video showing someone doing the whole operation. Saw one of two guys in Texas working on an Avalon but their scan tool gave more info on how to bleed. It appeared to be a standard Toyota bleeding with a new master cylinder/actuator.
    wondering if I can subscribe to tech stream for three days and connect to the Bluetooth scan tool I have instead of a mini vci. Gonna try with my laptop. Maybe on my phone? anything beats paying the dealer.
    maybe removing both poles on the battery will reset the brake lights? Only been removing the negative.
  19. ChapmanF
    18,515
    The key is the dongle has to support SAE J2534 for Techstream to be able to use it. Mini VCI and several others do, but also many do not.
    Removing both battery posts won't do anything more than removing either one does.
    Whatever gets cleared when you do that gets cleared, but might not be everything.
    C1451 officially does not get cleared by doing that; it's kept in nonvolatile memory so no power loss will make it forget.
    Other codes generally do get cleared that way, but that doesn't mean they won't be immediately back again, if the condition they're meant to tell you about hasn't changed.
  20. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Thinkdiag supports sae j2534. The laptop located the Bluetooth connection last night. just need the drivers and a three day subscription to tech stream to try again now.
