Master Driver Window Switch Not Working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by taxibuddy, Mar 14, 2018.
  1. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    Today my driver's master window switch won't open any doors and it also won't operate the door locks. The passenger side lock switch works fine to unlock and lock all the doors. All of the individual window switches operate the windows correctly including auto mode. The mirror controls near the driver master switch also work correctly.
    I'm thinking I need a new master window switch, but is there anything else I should check first?
    49,511
    check to see if there is a fuse. other than that, clean the contacts before replacing?
