Master warning light and transmission park lock
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by kdhorses, Jan 19, 2017.
  1. kdhorses
    kdhorses New Member
    Friendship, WI
    My master warning light came on with the message "The transmission P lock mechanism is abnormal. Park you car at a flat place, and aply the parking brake completely" . I did that but no change. Coincidentally, I needed a jump at the same time because the car wouldn't start when I came out of the store. Could this all be caused by a bad battery?
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Well the obvious way to answer the question is to replace the battery and see if that fixes the problem.
  3. kdhorses
    kdhorses New Member
    Friendship, WI
    That is my plan but was seeing if any other suggestions are had. Thanks
  4. Ernest magnelli
    Ernest magnelli New Member
    Six mile sc
    Cit could be something else,if you read a lot of post,it has me in a tissy, changed battery out of another I am driving,and the battery is good after the dealer said it was bad ??
    I have two a 2004 in original every thing except the major Warner pump changed under recall,and a 2008 that looks like a brand new one but all the lights are lit up and looses power,and battery heating up.?
