Master Warning Light no other lights or codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scott Otto, Jul 28, 2016.
  1. Scott Otto
    Scott Otto New Member
    Dixon, IL
    I have an 06 prius and have the Master Warning Light on periodically. I say periodically since it varies. Some mornings when it is cool and damp it is off, but when the car warms up it comes on. I have racked up 300K of mileage and have seen the posts for the big battery going bad. No othere lights and codes appartent.
    Is my light on for the battery?
  2. Patrick Wong
    18,200
    6,479
    Check the engine oil level.
  3. Scott Otto
    Dixon, IL
    Oil level is topped up from recent oil change. And do see some oil loss between changes.
  4. JC91006
    16,496
    8,406
    Has the light come on after the oil change?
  5. bisco
    49,728
    did you check it, or take someone's word?
  6. Scott Otto
    Dixon, IL
    I have been doing my oil changes for a while now so yes I know the oil level.
    JC: I have seen what happens when the oil goes low due to the burn off issue.
    The light also blanks the screen, i can clear the screen, but when braking to a stop it blanks out again.
