master warning,vsc,charging system warning light on?
Discussion in 'Gen 2 Prius Technical Discussion' started by esdras29, Jun 28, 2011.
  1. esdras29
    esdras29 best prius
    adelanto
    I HAVE A 2006 PRIUS WITH 127,OOO MILES, I WAS DRIVING TODAY AND THE master warning,vsc,charging system warning light on....
    ALSO THE A/C TURN OFF
    BUT I TURN THE CAR OFF AT MY HOUSE AND 2 HOURS LATER THE HYBRID SYSTEM WARNING LIGHT IS ON ONLY.... AND NOW THE A/C WORKS ... ANY INFO WILL BE GREAT..BUT TAKING IT TO THE DEALER TOMMOROW IF IS STILL UNDER HYBRID WARRANTY....
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Have you tried rebooting the car?
  3. esdras29
    esdras29 best prius
    adelanto
    how do i reboot the car ?
  4. Patrick Wong
    18,200
    6,493
    Most likely, the inverter coolant pump has failed. Your car should have been included in the LSC which will replace that pump at no charge.
    Check the inverter coolant reservoir when the car is IG-ON. You should see turbulence in the fluid which shows the pump is working. If you do not see this then the pump definitely needs to be replaced.
  5. esdras29
    esdras29 best prius
    adelanto
    ok today my car is back to normal ,no warning lights at all.....and also inverter pump they change it like 4 months ago at the dealer for the recall.....
  6. Patrick Wong
    18,200
    6,493
    Whether or not the inverter pump was already replaced, I recommend that you verify for yourself that the pump is running, via the visual check that I described above.
    If the pump has failed, then the car will work OK until the inverter overheats.
  7. esdras29
    esdras29 best prius
    adelanto
    came back from dealer and no codes were found :confused:
  8. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    That is weird! Hope it stays away. Makes you worry every time you start her up,don't it !H
  9. andyprius
    2,212
    188
    You probably inadvertently rebooted the system by restarting it, however the inverter system coolant pump should be paid close attention to in summer. I will not go into this subject or rebooting as there is already plenty of threads on both subjects. Just use Priuschat SEARCH. :D
  10. Prius 1966
    Prius 1966 New Member
    sacramento
    I HAVE A 2007 PRIUS WITH 187,OOO MILES, I JUST REPLACED ONE BAD CELL TODAY AND THE master warning,vsc,charging system warning light WENT OFF THEN COME BACK on BUT ITS CHARGING ..
    ALL BARES ARE GREEN
    BUT LIGHT IS ON
    ANY HELP PLEASE
  11. bisco
    51,155
    get a mini vci and report back here with the codes.
