Matching High -Beam bulbs to go with the TRS 5500k Morimoto Elite HID Kit ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Markee, Jun 15, 2016.
  1. Markee
    Markee Member
    327
    50
    South Florida Broward County
    Just installed TRS Morimoto Elite HID Kit with the white looking 5500k bulbs and now my high beans look too yellow
    Looking for a different bulb to go with that would get me a better match with the TRS 5500k bulbs ?
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    How often do you use your highbeams? Mine function 99% of the time as DRLs, not as highbeams.
    Same as foglights, rather than trying to match the HID lowbeam color, I go yellow. 2500K bulbs in foglights and highbeams.
    HelloHybrid, Xterra72 and Dylan Doxey like this.
  3. pauerbach
    pauerbach Member
    101
    34
    In my experience, replacing the high beam bulbs with LEDs will effectively neuter your nighttime visibility. Retrofit LEDs are either just too dim, or they don't work in the headlight's projector housing and end up scattering light everywhere but the road ahead. I know it's not the answer you were hoping for, but I'd just leave your stock high-beam bulbs as they are. If you really want to match the color, there are plenty of 6000k LEDs available, but just know they'll make for horrible high-beams.
    Dylan Doxey likes this.
  4. Markee
    Markee Member
    327
    50
    Why go yellow I don't get that ?
  5. Markee
    Markee Member
    327
    50
    I agree I wasn't particularly looking for LED bulbs I was looking for a better than the stock HID High beam bulb that came with the Prius one that more matches color wise with the whiter color of the TRS Morimoto Elite HID Kit HID 5500k bulbs I upgraded to
    #5 Markee, Jun 23, 2016
  6. xliderider
    8,056
    3,223
    Honolulu, HI
    For foglights especially, yellow provides better contrast on wet roads. White light tends to "disappear" when it's wet and rainy.
  7. Markee
    Markee Member
    327
    50
    I don't think i have fog lights fog lights sit in the grill area right?
    I just have the same running lights like you have in your picture but newer version
    But anyways I wasn't looking to upgrade the running lights or fog lights I was just looking for some bulb upgrade suggestions on the high beams because after updating to the Morimoto kit the high beams just seem to yellow and not a good match is all
