max mpg tips re: moving from dead stop?
Discussion in 'Gen 2 Prius Fuel Economy' started by beckerman, Oct 28, 2008.
  1. beckerman
    beckerman Junior Member
    56
    Short Hills, NJ
    In order to get maximum mpg, what is best method to accelerate from dead stop?
    ...from 0 to 25?
    ...from 0 to 60?
  2. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Manual acceleration to 33 mph, then cruise control acceleration above 33 mph. Tank and cumulative fuel economy = 53 mpg.
  3. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  4. rpg51
    rpg51 Member
    200
    Vermont
    Does it matter whether you are going uphill or downhill?
  5. Silver 2008
    Silver 2008 Junior Member
    71
    Idaho
    One thing I try to do when accelerating from a dead stop is "ease into it." I try to use the electric motor to move the first 5 to 10 feet with light pedal, then ease into it slowly. I try not to get the MPG under the 25 MPG line while accelerating. There is a fine balance between accelerating to get maximum MPG and being a traffic hazard.
    I think you will make more of a difference in the way you "cruise" than the way you accelerate. When I cruise above 30 MPH, I try to keep the MPG above 60. You can play with the throttle while watching the MPGs to achieve the optimum position.
    I also "encourage" the car to run on electric whenever I know I will be cruising on a flat at a constant speed under 40 MPH. To do this, I back off the throttle until it goes to "glide" then I apply slight pedal until it goes electric only. If the battery doesn't have enough charge, it won't do this.
    Mike
  6. beckerman
    56
    Short Hills, NJ
    Thanks to all, incl. Professor Catgic of the Prius Institute for Fuel Economy.
