MAX Weight
Discussion in 'Gen 2 Prius Technical Discussion' started by Devil's Advocate, Sep 19, 2007.
  1. Devil's Advocate
    922
    Las Vegas, Nevada
    I'm crazy, but I want to try and find the dangers out first:
    Test: three adults with luggage = 650 lbs
    Trailer: 6x10 = 500 lbs
    Load: 3 motorcycles = 1250 lbs (total all three)
    Trailed load = 1750 = 60% curb weight
    Load = 2400 lbs
    GVWR = 5300!!! (I know CRAZY) with a 3500 GVWR
    The towing dangers shouldn't be to bad with a 60% ratio, so I am not worried about handling and braking.
    The concern is in towing with the load on the CVT, trans temp and MIG Temp.
    I figure all can be minimized with slow accelerations so as to not put a high demand on the traction battery and thereby keep the rate of drain reletively near normal. (for me, as I usually accelerte pretty hard)
    I am having the CVT fluid changed this weekend since it is 118,000 miles, with the full flush in Vegas for $175.
    I have already pulled this load:
    two motorcycles w/ trailer = 1250 lbs
    two passengers w/ gear = 450 lbs
    Total load = 1700 lbs
    LA to Vegas = average speed 65, max 85, min 60
    No problems except ran out of battery up one of four grades.
    Questions:
    1. Will the ScanGauge II give me MIG I & II Temps?
    2. Will the ScanGauge II give me trans temps?
    3. Has anyone installed a transmission cooler? Is this even possible in the Prius?
    And now for my biggest concern...
    4. How are the loads transferred through the CVT/Planetary gear?
    4.1 Is the CVT able to compensate for the increased load by decreasing drive ratios and spinning faster? or is it just add torque to the gear until it moves?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    1&2. The current Scangauge will not display any CAN messages, which the ones you want are. They are "working on it - real soon now". If you have one, you will have to send it back to them to have it updated. Best to ask them which messages they plan to add.
    4. There really isn't a "CVT" as most of us think of one. The MGs are used to change the spin rate, sort of a magnetic CVT. Check out the sticky postings at the top of this page to visualize how it works. I'm not going to try to explain, as if I do my headache will get worse. ;)
  3. Devil's Advocate
    922
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(David Beale @ Sep 19 2007, 12:17 PM) [snapback]514912[/snapback]</div>
    First: What are stickies and where are they????
    Second: My real question is "Does the increased load in the car pass through the planetary gear as increased force or increased RPM?" If that makes any sense. I see it as there are two ways to get torque through a "transmission"; increased rpm or increased force
    Is the "magnetic" cvt able to spin up to handle more load or will it reach a "sliopping" point?
    Yeah, this is probably headache causing. I bet it would make a Toyota engineers head explode just thinking about it!!!
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I think David was referring to the two ''sticky" topics listed at the top of this Prius Technical Discussion forum: CAN-View Software Updates and Introduction to Prius Power Flow. The first may tell you what CAN-View reports and the second explains how the Prius sends power to the wheels to move the car and load.
    The HSD can not slip, it's all gears in fixed ratios. Speed and power to the wheels is varied by electronically changing the direction and speed of MG1 and MG2 and the speed of the ICE. Torque is what moves the car forward (or backward) and it is the computer that balances your accelerator pedal position demand with the available motive forces.
    The headache comes from trying to understand the planetary gearing of the HSD and the computer's algorithms for acceleration.
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    As I best understand it (hopefully someone will correct me if I'm mistaken):
    <div class='quotetop'>QUOTE(Devil's Advocate @ Sep 19 2007, 01:55 PM) [snapback]514903[/snapback]</div>
    Not yet. Perhaps "soon".
    Not that I'm aware of, but hopefully if someone is aware of such a completed project they'll see your question.
    Given enough time and enough resources. . . . I don't see why it wouldn't be possible.
    Not sure that I understand the question.
    Assuming you know what a planetary gear is, the ICE is connected to the "planets", one Electric Motor/Generator is connected to the "sun", the other Electric motor/generator and the wheels are connected to the "ring". Depending on the request from the accelerator pedal, the computer determines the "best" combination of torque to add from each of the three sources.
    The drive ratios are fixed and don't change. The CVT can add torque directly by sending electricity to the MG connected to the ring. It can also choose an ICE rpm to generate a chosen amount of torque, and then choose how much this force at the planets affect the ring by sending electricity to the MG connected to the sun.
    <div class='quotetop'>QUOTE(Devil's Advocate @ Sep 19 2007, 02:24 PM)</div>
    As far as I know, there is no clutch. There is nothing to slip, except perhaps the wheels spinning on the road. At that point the traction control would kick in and reduce power. and the car wouldn't move.
    The computer will use the ICE and the electric motors/generators to send power to the wheels as it sees fit to try and move the car. If a load was so high that the car won't move and if the wheels were somehow prevented from slipping, I suspect the car would end up in "force charge" mode, where the ICE rpm spins the sun and the ring/wheels don't move. The sun spins the generator and charges up the battery until it reaches it's charge limit.
  6. David Beale
    5,963
    1,989
    Edmonton Alberta
    I think I read "Bilsonforweb" is working on an HSD cooler (for his Prius classic). He plans on using the fill and drain plugs for inlet/outlet with an external oil pump. More oil would have to be added, of course, due to the extra volume in the pump, cooler, and lines. More oil is always a "good thing". Except when you have to pay for it. ;)
  7. priussoris
    priussoris New Member
    1,005
    I have towed a yamaha 4 wheeler on my small 4x8 utility trailer 140 miles no problem in any areas.
    but then the weight was very minimal trailer tonge weight only 30 pounds and the atv 397# was just like having 2+ of me in the back seat :D oh and 24# of petro in jerry can.
    [attachmentid=11543]
  8. Devil's Advocate
    922
    Las Vegas, Nevada
    Excellent Danny;
    I understand how the planetary operates, sort of;
    The question is "What is the force limit that can be transmitted through the Planetary gear system?"
    I'm sure toyota has a sensor that would prevent the MIGs from transmitting a load through the gears which the gears themselves were not designed to handle.
    What is the theoretical maximum force????
  9. richard schumacher
    7,664
    1,047
    United States
    You really don't want to do this. Along with possibly shattering the CVT your braking ability will go to hell.
  10. benighted
    benighted New Member
    530
    Westport, WA
    I helped my brother move last fall. The trailer was full and the motor seemed to be working pretty hard but it handled the load just fine. Most of the strain was caused just by the extra drag of the trailer:
  11. David Beale
    5,963
    1,989
    Edmonton Alberta
    Maximum torque the engine plus motor can deliver into the HSD gearing is 515 N-m or 380 ft-lb. There is a reduction gear between the HSD and the wheels, and I can't find the ratio at the moment, though I remember seeing it somewhere. It was between 1.5 and 3, as I recall.
    Anyway, this gives you an idea of the forces the system is designed to handle.
  12. richard schumacher
    7,664
    1,047
    United States
    <div class='quotetop'>QUOTE(benighted @ Sep 19 2007, 10:11 PM) [snapback]515095[/snapback]</div>
    And what was the weight?
  13. Danny Hamilton
    926
    94
    <div class='quotetop'>QUOTE(David Beale @ Sep 20 2007, 10:07 AM) [snapback]515246[/snapback]</div>
    Not that I don't believe you, but I'm just curious if you have a source for this information?
    Does anyone else know what the gear ratio is in this reduction gear, hobbit perhaps?
  14. Winston
    Winston Member
    614
    SF Bay Area, California
    <div class='quotetop'>QUOTE(Devil's Advocate @ Sep 19 2007, 03:45 PM) [snapback]515010[/snapback]</div>
    As Danny noted the maximum Force is 380ft lbs. However, I doubt that is really the answer you were looking for. You probably want to know how steep a hill you can go up while pulling a trailer, and/or how fast you can go up a certain grade. It can be calculated, but you would have to eliminate the power from the motor in the calculation, since eventually the battery would run low.
    If you did the calculation you would find that you would be calculating a maximum speed based on a certain percent grade and total weight of your prius + load. Their would be a maximum grade at which the Prius would not be able to move at all, but that will probably not be an issue. In the end you will be able to ascend any grade, just not necessarily as fast as you would like.
  15. Devil's Advocate
    922
    Las Vegas, Nevada
    The 380 ft/flb number is usefull in that it gives me a "desigend for" torque number. 380 is pretty high, and the engineers likely have at least a 10%, if not 50% margin of error for constant load, and probably a couple of hundred percent for short term or impact loads.
    Yeah, I figure this will be a long, slow trip. As I will be using the force, yes luke the force, no the force-over-time method to reduce the impact on the trans. So basically, accelerating really slowly and keeping a minimum the inputs neccesssary to maitain speed on large grades.
    I think the longest grades on th Vegas/LA route is about 20 miles at 3-4% and a shorter 10 mile grade at about 5%. (only estimates)
    I am having the trans fluid flushed this weekend just to be safe. I was going to add a trans cooler, but I think that the 2005 Prius has some type of trans coller integrated into it already. (if I read the other posts right)
    Also, that UHaul trailer below is 900lbs by itself, so figure it was about 1500lbs loaded. Plus its a brick for areodynamics. I will be pulling a flat trailer with three supersport motircycles on it, slightly more areodynamic.
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    04 final gear ratio is around 4.13 from my memory.
    MG2 can output 295 lbs-ft max at 0 rpm.
    Gas engine max torque is 82 lbs-ft at 4500 rpm(?) but only 72% get split to the wheel.
    Total output torque is about 1,462 lbs-ft (295+82*0.72*4.13).
    In your situation, the torque in PSD will not change. Just MG1 and MG2 will get utilized more and can overheat if cooling system can not handle.
  17. Winston
    Winston Member
    614
    There will not be more than a few percent margin on that torque number.
    As far as the design for the transmission gears, yes at least a 50% margin to ensure a reasonable fatique life.
  18. David Beale
    5,963
    1,989
    Edmonton Alberta
    My numbers are from Toyota documents, which I don't have the url for at this time, of course. It's the one that discusses the difference between the "new" THS II and the classic THS, with photos of the various parts, drawings, and the specification sheet, from which I got the numbers. I printed it out and promptly lost the URL. :unsure:
  19. Devil's Advocate
    922
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Sep 20 2007, 11:47 AM) [snapback]515373[/snapback]</div>
    Great info.
    After all the research I have come to the same conclusion, that it is the heat generated by the MIGs that is the most llikely failure or limiting point. Since there is currently no way to check those temps (ScanView taking a break) I am counting on two things, slow acceleration to minimize strain and some type of built in mechanism installed by Toyota which would shut the sytem done if the MIGs got too hot. Also, a fresh trans flush and refill.
    I'll take pictures, it should be a real sight.
  20. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(Devil's Advocate @ Sep 20 2007, 10:46 AM) [snapback]515338[/snapback]</div>
    Yeah, it was a brick and pulled about the same empty (round trips are cheaper), there was a LOT of drag but it handled fine. Averaged about 29MPG.
