Maxiapp diag 2500 reports hV battery needs balancing
Discussion in 'Prius c Main Forum' started by Adventurer2112, Feb 1, 2025.
  1. Adventurer2112
    Adventurer2112 Junior Member
    55
    Urbana
    2014 Prius c
    Hi 2014 C 170K miles. Pull over hybrid battery warning when temps were at 5* F. Now in 30s rarely get it. Just received the Autel Maxiap AP2500. Great tool, happy with it. the app reports the hybrid battery needs balancing.
    Is that viable ? Something to invest in OR buy a new hybrid battery from
    Ennocar direct ?
    TIA
    Jack
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    There is no need to change everything at once and tear your hair out.
    Can you attach the application report? Or a photo of the problem detected?
  3. Brian1954
    Brian1954 Senior Member
    2,401
    962
    South Central PA, USA
    Please list the actual trouble codes that the Autel AP2500 reported.
  4. Adventurer2112
    55
    Urbana
    2014 Prius c
    P0A80.
    S
    Reports the dtc as severe. jack
  5. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    P0A80 - replace the battery.
    Very scanty information.
    Of course, you can change the entire battery, throwing a couple of thousand out of your budget, but first it is better to find out what caused this code.
    You need additional codes removed by special devices compatible with the Toyota protocol.
    Voltage of pairs of modules under load?
  6. Adventurer2112
    55
    Urbana
    2014 Prius c
    Autel did NOT give any more codes. Dr. Prius, Carista with paid for enhanced abilities, OBD Fusion (confusing) nor Autel Maxiap Diag gives any more info. I use my C for deliveries, in town and a few days for 100 mile radius deliveries. Car works best when I don’t run the heat. tia
    Jack
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,501
    6,591
    Texas Hill Country
    Your Dr Prius report looks ok now.
  8. Adventurer2112
    55
    Urbana
    2014 Prius c
    Yes, Dr. Prius reports’ changes, doesn’t stay that way. Some event Triggers the pull over warning & P0A80. I bought the Autel Maxiap diag & obd2 dongle based on priuschat recommendations. Being Toyota aware.
    J
  9. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    The battery condition of the freeze frame of the doctor Prius is normal. The only drawback is the high temperature of the battery. This may be caused by dirt and fluff in the ventilation duct of the high-voltage battery. Have you cleaned the ventilation grille at the entrance to the ventilation duct lately?
  10. Brian1954
    2,401
    962
    The Dr Prius screenshot is NOT normal. For a healthy battery pack, the Delta SOC should be 0.0%. Yours is showing a Delta SOC of 42.5%. Delta SOC is the state of charge difference between the best and worst battery block. A battery block consists of two battery modules. A top balance of the battery pack with a grid charger may help to reduce the Delta SOC.
    Has any work been done on the hybrid battery?
    #10 Brian1954, Feb 4, 2025
  11. Brian1954
    2,401
    962
    HV battery temperatures of 97F and 101F are NOT high temperatures. They are normal temperatures.
    #11 Brian1954, Feb 4, 2025
  12. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    This is not an application from Toyota Techstream.
    This is a program that does not have open source.
    Aren't we too trusting programs made on the knees?
    The physical meaning of the SOC delta is in the large difference in charge between pairs of modules.
    Is it really as the program says?
    On the freeze frame, the minimum voltage is 16.62, the maximum is 16.7.
    The difference between them is 0.08V Less than 0.5%
    Is the freeze frame the same when the error was detected and what preceded it?
    In this case, it is more objective to use the Hybrid Assistant. It takes a graph during the discharge or charge process and the difference between pairs of modules is clearly visible.
  13. vvillovv
    vvillovv Senior Member
    4,329
    1,514
    NY
    J post a DrPrius screenie before you start your daily work, right after you put your C in ready mode. Preferably after sitting all night in sub freezing temps.
    than, next time you get the pull over and Triangle of Death, after pulling over, grab a DrPrius screenie of the packs condition before doing anything else, if possible.
  14. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    If a 2014 Prius c showed a P0A80 in front of me I'd just replace the hybrid battery, no need to mess around.
  15. Brian1954
    2,401
    962
    The Dr Prius app is just retrieving some of the parameters that are in the Hybrid Control ECU and the HV battery ECU and presents it in a user friendly GUI. The Delta SOC is a Toyota parameter that is in one of the two ECUs. It is not created by the Dr Prius app. I have uploaded one page of the Gen 2 Hybrid Battery System manual as a PDF. You will see that Delta SOC is one of the parameters that is included in the freeze frame data. Here is a link to Techstream freeze frame data that was included in a different thread for a Gen 3 Prius. The Delta SOC is on page three of the PDF. https://attachments.priuschat.com/attachment-files/2024/08/253941_Freeze_Frame_Data_08-03-24.pdf
    Delta SOC is not the same as the voltage difference between the battery blocks.They are two different parameters. When the Delta SOC is more than 0%, it means that the battery blocks are not balance to each other. Toyota says that Delta SOC should not exceed 20%. See second PDF uploaded below.
    Adventurer2112's HV battery has a Delta SOC of 42.5%. To reduce the Delta SOC, a grid charger should be used to top balance the battery pack. After the battery blocks are balanced to each other, than he should not see the P0A80 code again.
    #15 Brian1954, Feb 6, 2025
  16. Brian1954
    2,401
    962
    Rather then taking the two Dr Prius screenie that you requested, take a look at the freeze frame data for the P0A80 code. Then you can see all the data seconds before the trouble code was triggered, and the data when the trouble code was triggered.
    Edit: A link to P0A80 freeze frame data for a Gen3 Prius is shown in my post #15. If you look at that PDF, the columns marked as "-3", "-2", "-1", are the data just before the trouble code is triggered. The "0" column is the data when the trouble code is triggered. The column "1" is the data just after the trouble code is triggered.
    #16 Brian1954, Feb 6, 2025
  17. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi Thanks Bought the charger discharger system $700 My system reports 62 % stable charge, but I have codes that won't allow me to start car.
  18. Brian1954
    2,401
    962
    What are the codes?
  19. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi All, please help
    Me. TIA
    Using Prolong charge/discharge system got battery level to 62%. Stupidly Sprayed Deoxit into connectors I opened under the hood. Put connectors together 3 hours later. Tried to start at twice. No go many codes popped up. Unhooked connectors. Dried out with hair dryer.
    Car doesn’t register as in park to start. Took weeks but Finally got vadiag cable, nano tool with cable, Windows 10 laptop & techstream v18. AND all this tech working together. I hate windows.
    Codes are pAo0D hi voltage system interlock snowflake symbol , P0A80 replace hybrid battery, P0AA6 hybrid battery voltage system isolation fault snowflake symbol, p3110 HV main relay snowflake symbol, p308A hybrid battery voltage sensor all circuits low
    ABS/VSC/TRCC1259 HV/EV control system regenerative malfunction, C1310 HV/EV system
    Malfunction,C1259 ABS/VSC/TRC, C1345 linear solenoid valve offset learning undone ( by me) B1826. Abs sensor (under drivers seat unplugged, haven’t messed with it.)
    6 Various wheel Speed sensorDTC cleared
    By tech stream.
    I’m in over my head but determined to learn. thanks again
    Jack Champaign, Illinois
  20. Brian1954
    2,401
    962
    What connectors under the hood did you spry the Deoxit into?
    You purchased the Prolong charger and discharger and installed the wire harness to the hybrid battery. Did you follow the Prolong instructions and do all the charging cycles and all three of the discharger cycles?
    It sounds like you got Techstream working on a Windows computer. You listed all the trouble codes detected. You need to pay attention to whether the codes are current, pending, history, or permanent. The codes listed as current are the most important ones.
    It looks like the first code you listed was a typo. I believe the code is P0A0D High Voltage System Inter-lock Circuit High. This is a code that will prevent the car from starting. So this is the first code to fix. Most times, this is present because the orange safety plug was not installed correctly. There are three steps to install the orange safely plug.
    1. Insert the plug into the socket.
    2. Flip the lever of the plug.
    3. Slide the lever. This last step is something not completed, which will cause the code.
    Here is a diagram from a Gen 2 Prius.
    #20 Brian1954, Jun 28, 2025
