Maximum Regen Efficiency
Discussion in 'Prius v Technical Discussion' started by SageBrush, May 8, 2014.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    This is probably relevant to any 3rd Gen Prius, but since the testing was in a v(agon) I am posting in this sub-forum.
    I have the Torque app, and I know I can ask OBD for the current flow into the battery while I am braking. To have another data point to compare, I took advantage of a hill I drive down a couple days a week where I keep my speed below 45 so the ICE is not spinning, and collect regen leafs. Google maps gave me the distance and elevation drop, so using energy = m*g*h at
    m = 1550 kg
    g = 9.8
    h = 76 meters
    I calculated 320 Wh of potential energy.
    Wayne Brown calculated 150 Wh to travel 1 mile at ~ 40 mph on level road
    I collect 3.5 leafs of regen, equal to 105 Wh.
    All told, regen collects 105 of the 170 Wh available, equal to 61.7% collection efficiency.
    This should be viewed as just about a best case scenario, but it is terribly impressive none the less.
    Does it about match what others have measured, or read ?
