Maximum Weight on Prius Roof
Discussion in 'Gen 2 Prius Main Forum' started by Gmer, Sep 26, 2009.
  1. Gmer
    Gmer New Member
    Columbia, SC
    Does anyone have any recommendations/experience as far as how much weight can be loaded on a roof rack on their Prius?
    I have a 2007, and would like to transport two 60 pound kayaks. Am looking at buying a Thule rack with two lift assist devices (Hullavator) that will add approximately 90 pounds (rack included), so to be safe I'd say 200 pounds would be on top of the car.
    Anyone know if this would be a problem?
    Thanks in advance!
    George
  2. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Greetings, new poster. The roof racks themselves typically give a weight limit in the range of 200 pounds. This amount is fine for Prius assuming the rack is well designed (Thule is, among others).
    You fuel economy will be reduced starting at about 40 mph, and the effect increases rapidly at higher speeds.
    There is an older thread here about risks of 'losing" the roof load at speed. You don't want that, so fasten everything securely.
  3. mrrobwood
    mrrobwood New Member
    Dracut MA
    Hi.
    I have had good luck with my Yakima racks. I have had two kayaks on there at one time. They probably weigh 100 pounds put together. Yakima advises not to put more than 100 - 120 pounds on the racks. I think 200 is pushing it, but you could try it.
    As far as weight on the roof, I don't think I would push much more than 150 pounds, but that is just my opinion.
    Also I should add, the Prius does well holding two kayaks. It blows around a little bit on the highway but all in all it's not bad. I drive to Maine from Massachusetts with two kayaks on the roof and back and average about 40 - 42 MPG's
    I would reference Thule and Yakima's websites for exact numbers.
  4. Gmer
    Gmer New Member
    Columbia, SC
    Thanks much for the advice and sharing your experiences; I think I need to do a little more research to increase my comfort level this is doable.
    Best,
    George
  5. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi George. Have you considered a light weight trailer? Take a look at these links, they're from a guy called EV-NUT (aka Darell) who I believe is also a member of this forum.
    EV page
    SportsRig trailer
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    That's the one we have. It's a very nice setup.
    Tom
  7. barry3199
    Boulder Colorado
    George, what did you find out? I just saw a used hullavator for $125 but missing some parts I could buy online. Did you get it? I have 2007 prius also. Have been strapping my 2 heavy kayaks on thule bars upside down with foam cushions. I'd like to know if you or anyone ever got the hullavator to fit and work successfully. Thx
  8. ChuckDorsett
    ChuckDorsett New Member
    Barry3199, I carried two sea kayaks and/or a sea kayak and a canoe on top my 2007 Prius with no trouble whatsoever for several years using Yakima QTower/ [round] Crossbar. Max weight was probably around 120lbs. Would also recommend using the font and rear tie-downs, and fortunately the Prius has convenient places underneath the car to hook onto.
  9. black_jmyntrn
    black_jmyntrn Senior Member
    1,300
    340
    2013 Prius Plug-in
    Hmmm interesting topic here, I've carried a lot more then 200lbs on my roof, from Los Angeles to Alaska and back actually. No issues or leaks....
    Toyota prius low profile roof rack
  10. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    I run a Thule Weekender roof box on my OEM bars ( Same as Thule Aero bars)
    It weighs 19kg with a “max weight limit” of 75kg
    converting to pounds - gives you 207 on the roof bars
  11. black_jmyntrn
    1,300
    340
    2013 Prius Plug-in
    why does that seem so mediocre? ~200lbs
  12. PaulDM
    616
    318
    UK
    2022 Prius
    Excel
    Well…
    Isn’t the average weight of an American man 197.9 pounds
  13. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
  14. black_jmyntrn
    1,300
    340
    2013 Prius Plug-in
    I can only hope through eating better and more hot yoga I can get below 250lbs.
    PaulDM likes this.
  15. PaulDM
    616
    318
    UK
    2022 Prius
    Excel
  16. Another
    1,802
    511
    Naples, Florida
    Denial
  17. PaulDM
    616
    318
    UK
    2022 Prius
    Excel
    :) oh so funny. When you look back at the posts and realise what you are arguing about. My point Is 200lbs is the weight of an average person. Not “all Americans are fat”. Re read your comments.
