Maybe wheel bearing worn at 85k miles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Jan 10, 2019.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    I recently bought a used 2015 Prius Plugin, now at 85k miles a noise of a possible worn wheel bearing or CV axel bearing (if any) started to appear. Sounds like coming from the drivers side.
    I wonder if this is a common issue in Priuses this age and if it's not a bearing what may be the issue?
    Thanks!
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    It may or may not be the bearing or CV joint. But it's not common afaik. My '13 has just under 87k and is quiet as a mouse.
    51,932
    does the sound change with speed or turning?
    85k isn't common, but we do see it across all prius, usually road salt
  4. galileofigaro
    37
    2015 Prius Plug-in
    Increases when turning left, like when taking a ramp into the expressway.
  5. bisco
    51,932
    i think that means cvj. take a close look at the boot for cracks
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    I'm thinking the same as @bisco here. I've had that on other cars.
  7. galileofigaro
    37
    2015 Prius Plug-in
    I will. Thanks guys
    bisco and jerrymildred like this.
  8. Mendel Leisk
    41,452
    CV joints failing would cause a rhythmic clicking during turns, typically one direction, varies with speed.
    One thing with wheel bearings, just my thought: I think Prius owners are more inclined to set tire pressures significantly higher. Maybe this increases the stresses on wheel bearings? And who knows what the previous owner was setting pressures at.
  9. galileofigaro
    37
    2015 Prius Plug-in
    Mine is like a mouse eating a cracker, sort of
    Raytheeagle and jerrymildred like this.
  10. bisco
    51,932
    that is one of the best car noise descriptions i have ever heard:)
  11. jerrymildred
    11,517
    14,152
    Tampa, FL
    Interesting description. What about putting it up on a jack stand and putting it in neutral so you can try spinning it by hand and tracking it down that way?
    Data Daedalus and Mendel Leisk like this.
