Mazda 6 diesel. Sign me up.
Discussion in 'Diesels' started by massparanoia, Mar 22, 2013.
  1. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    ralleia likes this.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Looks like they made the age old mistake of assuming UK mpg's are the same as US. You'd also be lucky to get anywhere near 57 mpg UK in one as the European fuel economy tests are not worth the paper they're printed on. Start stop technology, 0-60 times measured in minutes, grills taped over, engines running on non available thinner oil, all to get better stats.
    BBC News - 'Carmakers manipulate emissions tests'
    2sk21 and austingreen like this.
  3. massparanoia
    697
    467
    Virginia
    Yeah I figured the stats will be lower when it comes stateside. I've heard talks of 45 hwy when it comes here.
  4. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)We're moving away from a diesel. After years of paying higher than premium fuel prices for diesel fuel and so-so mileage, there are better alternatives. Say, a high fuel mileage vehicle that uses regular gas...
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Now they smog our diesels and you have to use UL Sulfur. Industry still runs on diesel, but someone higher up doesn't want it in US cars. From what I understand, even the "real" mpg diesel options in Europe far surpass most of the US gas MPG options. But what do I know, and it doesn't matter because we can't have them anyway.
  6. massparanoia
    697
    467
    Virginia
    A high mileage car that looks, rides, and drives like a "normal" car sounds like a win to me. And if the premium isn't that much more than the "regular" 6 Mazda could have a winner on its hands.
  7. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    The above number is from NEDC test cycle and it has nothing to do with EPA number.
    It's basicly the same Skyactiv engine as it's used in Mazda CX-5, it has some brake regen improvements (i-eloop with capacitors), you can expect around 40-50 MPG in real world, it's good but still lacking >10% behind Prius considering fuel energy content and CO2. It's priced a little higher than Prius, but you get more (room, power) for the money.
  8. Much More Better
    Much More Better Active Member
    655
    163
    Does current diesels still start well in Canadian winters? My experience with diesel has been limited, but when I do see them, it ain't pleasant. Noisy, hard to start.
  9. massparanoia
    697
    467
    Virginia
    Depends how far north you are. My experience with modern diesels in New England winters has been good. Glow plugs typically need 10-15 seconds to reach temperature. If you live really far up with extreme cold I suspect a block heater will be beneficial regardless of if you have a gas or Diesel engine.
  10. GasperG
    1,168
    598
    Slovenia
    2018 Prius
    Winter blend diesel is important, where I live it's rated for -20° C (-4 ° F), in northern countries I think its rated even lover. Fuel filter can be problematic, so it's suggested you change it regularly. When cold the engine may sound more like an older diesel, but it runs. I'm talking in general, not for the Mazda.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I remember an old American car a friend once had. It was a 6 litre engine that got 12 mpg and only had 120 bhp, had a mechanical points ignition system, you had to manually grease the nipples on suspension parts. Does that mean all American cars are crap? Nope. Times have changed since 1978.
    massparanoia and xs650 like this.
  12. austingreen
    austingreen Senior Member
    13,564
    4,101
    Austin, TX, USA
    I don't know how cold it is to start, but the skyactiv is not like the old diesels. It has some high precision high pressure direct injection that helps atomize the fuel firing as many as 9 times per cycle, as well as variable lift on the valves, allowing it to suck the warmer exhaust back into the cylinder for cold starts. glow plugs should do the rest. Unlike many of the modern european diesels the low compression allows it to have lower NOx emissions eliminating the need to have a urea tank for scr. NVH should be higher with a diesel than a gas engine, but it should not be as rough as the old diesels at all.
    The big question is how it will do on epa tests, and we need to wait for that. My guess is it will be a little better than the vw tdi engines are because of electrical storage into the supercap, but we won't know for sure until later.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    This UK website says 108 gC02/km combined. For comparison, Prius is 89 gC02. This suggests that normalized fuel cost will match a 41 mpg petrol engine in the US. Definite improvement over Vdub, but barely into Prius fuel economy territory.
    Kudos to Mazda for hitting Euro2015 without SCR.
    This car is about as good as it gets diesel tech wise in Europe for a car of similar specs. Since it is coming to the US, all the people who have been crying that the US market has been ignored by the diesel crowd will get to put their money where there mouth is. I'm guessing most will crawl back in their holes, thinking that once again a sub-par diesel has come here, never realizing why the Euro numbers look so much better.
    Sounds like a competitive car for people with old-style preferences of looks, who are somewhat hard of hearing.
  14. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    The only drawback I can think of is how expensive diesel is to maintain and repair.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    For comparison the gen2 Prius got 104g/km. The newest Honda Insight gets 96/105g/km and the Prius Plus (Euro version of the Prius V) gets 96/101g/km. The Euro versions of the latest VW Golf (not GTI) get between 99/123g/km.
    So 108g/km aint bad for a diesel car considering its size. OK, it's a manual, but some people might not mind that if all they do is highway driving.
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    It's a Mazda diesel, not a VW!
  17. SageBrush
    11,627
    2,530
    Southwest Colorado
    While the current T3 Prius is 89 gC02/km. Odd, since the EPA only improved ~8.7% between generations.
  18. El Dobro
    El Dobro A Member
    6,978
    3,213
    Didn't see anything on Mazda's USA website about any diesels yet.
  19. ewxlt66
    535
    186
    Dana Point, CA
    Pretty sure it's just Europe...like most cool small diesels.
  20. massparanoia
    697
    467
    Virginia
    Mazda has some pretty good tech in their new diesel, it will be interesting to see how it performs stateside. The ieloop system is an interesting take that is uses capacitors instead of batteries to store energy. If it performs as good as they are saying I might have found my next car when I finish my bsn. Unless there is a 30 k pure electric with a 200 mile range available by then.
