Meaning of A/C ECU diagnostic code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drive2much, Jul 10, 2010.
  1. drive2much
    drive2much Junior Member
    42
    Denver
    Having A/C problems. Ran the self-diagnosis function on the air conditioning ECU. Got a flashing 21 for the sensor check. Anybody know what that means? Thanks!
  2. Patrick Wong
    18,200
    6,493
    B1421/21 means that there is an open or short in the solar sensor circuit. The problem areas include the solar sensor, the wiring harness, and the AC amplifier.
    The repair manual notes that if you are doing the check in a dark area, that DTC might come up without an actual failure. In that case the DTC should go away after ~8.5 minutes.
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    I would say 60-70% of Gen2's that I scan with Techstream have a B1421 "solar sensor" error.
    Ignore it, unless you specifically have an AC problem.
