Measured oil consumption. How is it doing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by VFerdman, Apr 10, 2018.
  1. VFerdman
    VFerdman Senior Member
    1,185
    1,212
    Western Massachusetts
    I have replaced the engine oil at 180K with Mobile 1 5W30 Full Synthetic about 6 months ago. I am now at 188,500 and have added a total of about 4 quarts since the oil change at 180K. I think this is very reasonable oil consumption. What say you? I think for a car with this kind of mileage about half a quart per 1K miles is not so bad. Am I correct in not worrying about this?
    BTW, I plan on changing the oil at 190K. I think 10K interval is perfectly reasonable for an engine that runs less than 100% and full synthetic oil is used.
    m.wynn likes this.
  2. JC91006
    16,673
    8,518
    These threads will always give you varying answers as everyone does this differently.
    On a used high mileage car, I like to change the oil more often, using Dino oil. Since your car burns oil, I wouldn't want to keep putting expensive oil in it. Keep the synthetics for cars that don't burn much oil.
    Half a quart every 1000 miles is really nothing to worry about.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    That seems a little on the high side. Your cat converter will fail sooner or later because of this amount of oil :(
  4. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Mine also uses some oil, not as much as yours though. But I might be driving slower (overall) on the highway, and higher speeds may correlate to increased consumption.
    Generally use a thicker synthetic and change it around 5k or whenever possible, oil is cheap (when on sale) and a new engine/cat not so much.
    m.wynn, Raytheeagle and VFerdman like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Move up to 5-40 it will help.
    m.wynn and Raytheeagle like this.
  6. VFerdman
    1,185
    1,212
    Will the 5W40 oil cause more strain on the engine components? Will it cause more gas consumption? If the system was designed for 30 and you increase the viscosity by 30% I think there are going to be consequences. And not necessarily good ones. I am really not a fan of using oil viscosity not recommended by the manufacturer. Especially to remedy an problem that is not really that much of a problem. Am I going to cause more harm that just having half a quart/1K miles usage?
    I really think half a quart per 1K miles is no so bad. My gas cars have used as much as 1 quart per 1K miles (this includes a brand new Volvo I bought in 1998 and manufacturer's position is it was well within spec).
    As for throwing synthetic in there I really do believe synthetics last longer and so I am very comfortable with a 10K interval using full synthetic (and on a hybrid which has lower duty cycle on the gas engine). Mobile 1 costs around $5/qt (in 5qt jugs at W) vs. $2.50/qt (same form factor) for dino oil. If I double the interval with synthetic, then it's a wash cost-wise and less work for me.
    Those are my thoughts. I've been wrenching on my own cars since I was 16 (many summers ago) and am pretty good at keeping my rides in good shape, but not over-maintained. This being my first hybrid I am in learning mode.
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I put rotella T6 10 or 15w40 in my 2005 years ago. It's still running and has over 310k miles. I always joke with my family members that still drive it, telling the to just dump anything in the crack case just make sure the oil level isn't low!
    Maybe honey, or blueberry syrup next?? Lol
    m.wynn, edthefox5 and SFO like this.
  8. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    For almost 200k miles, still moving under its own power is an accomplishment as most cars are in the junkyard by then.
    My only experience with significant oil consumption was an 80s Ford that used a quart about every 800 miles at 100k miles. The converter was fine, but the EGR valve got fouled and stuck closed.
    VFerdman and Raytheeagle like this.
  9. VFerdman
    1,185
    1,212
    Modern cars (say from 1990's and newer) routinely last over 200K miles. With adaptation of electronic engine and fuel controls 200K miles is not even a slight problem to achieve. I have had a Volvos from the early 90's and late 80's get close to half a million miles and still have perfectly running engines (with others things failing). They did use some oil. I am kind of used to 1qt/1K miles being "normal" on gas cars. It took American cars a bit longer to even adapt a 6 digit odometer, but they finally got there and nowa days 200K miles is no big deal for just about any car sold in this country, I think.
    Aaron Vitolins and Raytheeagle like this.
  10. tpenny67
    464
    403
    Massachusetts, USA
    Yes, but any place I see actual data on the number of cars over 200K miles, like [[ bad link removed ]] it's all in the single digit %. Still, that means millions of cars do last more than 200K miles, but that's out of half a billion vehicles on the road.
    World wide lots of people live to be 100 years old, but that doesn't mean you can say most people will see 100.
    For every car that hits 200K miles, there's probably several that were totalled out before then, or rusted out after 20 years of low mileage driving, etc.
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
  12. tpenny67
    464
    403
    Massachusetts, USA
    Here's another attempt at posting that link. (click on the word "link")
    Silly board kept expanding it to many pages of HTML
  13. VFerdman
    1,185
    1,212
    I think there is a difference between "ABLE" to go over 200K miles and "ALLOWED" to go over 200K miles. Most passenger cars built today are totally capable of reaching and exceeding 200K miles. It's not that big a milestone anymore.
  14. edthefox5
    10,096
    4,831
    Clearwater, Florida
    The consequences will be it Will use less oil. And use cheapest Dino oil you can find 40 weight.
  15. VFerdman
    1,185
    1,212
    ... and use what change interval?
  16. edthefox5
    10,096
    4,831
    Clearwater, Florida
    You don’t need a change interval it’s changing itself at the rate your losing it.
    Hence the cheap 40 weight oil.
    tpenny67 likes this.
  17. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Wrong.
  18. tpenny67
    464
    403
    Massachusetts, USA
    I've noticed that the cars most likely to go over 200k miles are driven a lot, like 40k - 50k a year, so that age doesn't become a factor. Your Prius should easily reach 200k, and that means you'll have more mileage than 98.9% of the Prius on the road (or more likely, 98.9% of used Priii for sale, which is where they got those numbers if I'm not mistaken).
    200k may not be a rare thing, but certainly if you weren't dilligent at checking and adding oil your post would have been "is it worth replacing the siezed engine in my 11 year old Prius?" Point is it's still a big milestone and you can take some of the credit for it.
  19. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Oil weight is not a recommended method to address oil consumption by any OEM. Simple fact is and the OP got this right, the engine is DESIGNED for 10w-30. Considering 0.5qt/1,000 miles is completely normal consumption, there is no logical reason to change anything.
    Can 15w-40 be used in a Prius? Sure. Do it in a cold climate and you likely won't have to worry about changing it again as the oil starvation to the valvetrain will likely kill it the first winter.
  20. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Yes 15w-40 is not a good idea in cold climate. But you can get 10w-40, 5w-40, and even 0w-40 oils.
    European version of gen 2 Prius owner’s manual does says it’s ok to use 15w-40 if it’s not cold or even 20w-50 in hot temperatures.
    Difference between Xw-30 and Xw-40 can also be basically nothing as at 100c or 212F Xw-30 is between 9.3 and 12.5CSt and Xw-40 is between 12.5 and 16.3CSt. And that’s just one temperature as the thickness changes with temperature.
    If engine is worn enough that oil pressure is effected thicker oil can be used to get the pressure closer to normal value.
    #20 valde3, Apr 12, 2018
    SFO likes this.
