Mech. key won't work !
Discussion in 'Gen 3 Prius Main Forum' started by magnumrtawd, Jun 8, 2017.
  1. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    My 2010 pri. with sks has been working great. The dash started to say key not detected on occasion. Locking and unlocking with the remote and the car started and ran OK. I Suspected the remote batt. needed replaced. Opened the remote and the 3V batt. tested 2.8V. So I installed a new one that tested at 3.18V. The fob will not work at all now! The little LED light on the fob will not light at all! And,YES the batt. is installed correctly. I tried to start the car with the mech. key with no luck. I get a message that says(step on brake and press key to start button) The orange triangle lights up also.
    Now, my second fob starts and functions normally. But, it also will not start the car with the key. Manually! Help!
    51,140
    a new battery should 3.3 v, but i'm not sure that is the problem. i would take it apart and look everything over, make sure no buttons are stuck and etc.
    what do you mean, 'the mechanical key won't start the car'?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    What kind of battery is it? Some reports here of knock-off batteries creating issues.
  4. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    Hello. I have inspected the circuit board with a magifying glass can't see any cracks. Manual says to step on the brake and push the power button with the metal key to start the car if the fob battery dies. That will not start it!
  5. Prodigyplace
    12,403
    11,681
    Central Virginia
    I think you are supposed to place the fob over the start button so it sees the RFID chip. Not the mechanical key.
    DonDNH, Mendel Leisk and bisco like this.
  6. bisco
    51,140
    i've never read that. mine says to hold the fob up to the power button while pushing it. the metal key is only for unlocking the door.
    edit; you beat me.:p
    Prodigyplace likes this.
  7. Mendel Leisk
    40,574
    The couple of times I've opened the fobs my impression is they didn't make much effort to bullet proof this thing. The fragile circuit board is completely exposed. I think a better design would have an isolated battery bay, that you pop open WITHOUT the whole thing being open and apart.
  8. bisco
    51,140
    but mendel, that would cost another 17 yen per fob.:eek:
  9. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    OK, Thanks for the replys.
    The message on my dash says apply brake while pushing start button with the key.Not the key fob!
    I have found that my fob and the RFID chip are fried!
    Took the batt. out of my other fob and I can start the car manually.
    Any vender for FOBs that are reasonable and honest?
  10. bisco
    51,140
    idk, there are so many fob threads here, gen 2 and 3 are different, you can buy them new and used on ebay, there is something called the 'chicken dance', sometimes a local locksmith can help, it goes on and on.
    hopefully, someone else has the answer, all the best!(y)
  11. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Just for the record, IIRC, when you hold the key fob (not the key) up to the start button, it matters which end of the fob is pointed towards the start button
  12. Prodigyplace
    12,403
    11,681
    Central Virginia
    I assumed you would hold the fob with the buttons facing you and the back against the Start button, not using one of the ends.
  13. PriusNeckBeard
    376
    211
    Cincinnati
    Just saying.....if battery-less fob doesn't work, experiment with key fob orientation.
    I have to do tis occasionally.
    I keep a mech. key behind the license plate. (The screw that holds the license plate on also holds the mech key.) And a battery-less fob hidden in the car. I can get into and start the car any where any time if needed. (like if my keys get lost on vacation). Once, at home, I couldn't find my regular keys. I fished out the spare, held it up, started the car, went to the store. Handy.
