MECHANIC HELP - P0420
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by confusedcole..., Nov 13, 2024.
  1. confusedcole...
    confusedcole... New Member
    Humboldt county
    I've just smogged my 2008 prius and it passed and then I changed my coolant. as soon as i turn the car on to start bleeding coolant, car starts throwing code p0420. This is a cat code but does anyone know if this code be from air bubbles in the system or something along those lines? Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,003
    2,330
    Durham NC
    No you just got lucky next inspection you're going to need your cat dealt with or maybe some chemicals poured in it but that's just a stopgap measure possibly for the next inspection
  3. Kenny94945
    Kenny94945 Active Member
    850
    426
    Sausalito
    2016 Prius v wagon
    FWIW 0420 indicates a Cat Convert Oxygen sensor error.
    Coolant level or bubbles would not cause this code.
    First, clear the code and see if it resets, it may be Murphy's Law/ coincidence and there is no issue.
    Second, look to see if you damaged the wiring during your coolant change.
    It may well be, as the Prius is stock, that the sensor has failed and you need a replacement.
    The worst case is that the cat has failed by time or some fuel additive contamination.
    I don't believe an exhaust leak will cause this code.
    A workaround is to buy a spacer to raise the sensor.
    Good luck.
  4. Tombukt2
    13,003
    2,330
    Durham NC
    I believe that code is the catalyst is below the threshold has nothing to do with the sensor of course the sensor is reading that and that's how it knows that the converter can't pass the flood test that the car gives it whenever it says it does and that's that You can change O2 sensors all you want I don't think that will clear your catalyst below threshold code but you're welcome to try spacing out that downstream O2 sensor I don't think will fix the problem it may make the sensor not read as well and not code and that may get you by where you are it may not
    Brian1954 likes this.
  5. PriusCamper
    PriusCamper Senior Member
    12,774
    5,175
    Pacific Northwest, USA
    Sometimes a bad tank of gas can cause this...
    Tombukt2 likes this.
  6. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    No, it doesn't. It means the test of the catalytic converter does not meet the threshold to pass the test. While it rarely can mean a problem with the sensor, it usually doesn't.
    A mistaken belief. A P0420 can definitely be from an exhaust leak upstream of the sensor.
  7. Tombukt2
    13,003
    2,330
    Durham NC
    Yes but you will know it . I'm guessing a serious blockage could create code too. But car won't run exh blocked like that.
