Mechanic saying need new brakes what do i need to know ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Markee, Oct 3, 2018.
  1. Markee
    Markee Member
    334
    South Florida Broward County
    In for a tire rotation today mechanic telling me my pads look very low maybe 20% left got a 2013 level 4 with about 49k miles.
    Anything special I need to know before moving forward like does it take any specific specialized experience to do Prius brakes right ?
    Is there any kind of wear sensor light that lets you know when your brakes need replacement before you start cutting into rotor other then the wear indicator bar scraping sound ?
    Which replacement pads do people recommend this guy says he uses Wagner says there way better then Toyota OEM pads ?
    What should i expect to pay for all 4 this mechanic quoted me $270 ?
  2. JC91006
    16,827
    8,600
    This is probably just a way to get money from you. Your brakes shouldn't be worn at such low mileage. They should measure the thickness of the pad and put it in writing, so you can call them out on their lie.
  3. Markee
    Markee Member
    334
    Right thats how it is need to be a smart consumer almost everyone's trying to sell you something or up-sell you not just mechanic's
    This guys telling me no matter who I use don't wait telling ,me pads are definitely very low and saying It will start to cut in to my rotors very soon ?
    I do use the vehicle for work purposes alot of stop and go local city driving fire extinguisher guy going from business to business all day so might be possible.
    So what do you people recommend ?
    Really don't feel like going waiting for some place to pull my tires and check then again
    So I ask again does the Prius have some kind of sensor light that lets you know when your brakes need replacement before you start cutting into rotor or is it just that wear indicator bar scraping sound ?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The most reliable way to find out would be to look in the owner's manual. Unfortunately, I don't have a 2013 owner's manual. Anyone out there have a 2013 owner's manual?
  5. Mendel Leisk
    41,905
    The inner pad has a copper "handle", with a little tang which will start contacting the rotor (and making lots of noise), when you've got maybe a millimeter left.
    You can do quick check of remaining pad thickness yourself, even without removing the wheels, though pulling a wheel makes it easier. This is doable even with scissor jack, and a good exercise if you've not done it before, just to see what you're in for if you have a flat.
    Loosen the lug nuts before raising the car, not completely, just enough that'll be easy to loosen them the rest of the way when the wheel's off the ground. Chock the wheel diagonally opposite. All this stuff is in the Owner's Manual. Torque for the lug nuts is 76 ft/lbs, and reinstall them in a star pattern.
    Even without the wheel off: look through the wheel opening, with a good light, check for yourself. There's a backing plate and beyond that, touching the rotor, is the actual pad material. You should be able to eyeball it. The start out at 10mm, service limit is 1 mm, but anything around 2~3 mm I wouldn't wait too long.
    I'd be inclined to use the Toyota pads.
    The $64 question: when was the last time you had a complete brake inspection, not the visual check during tire rotation? Toyota USA tells you to do this every 3 years or 30,000 miles, whichever comes first.
    I've attached the Repair Manual info.
    #5 Mendel Leisk, Oct 3, 2018
    scona, Bay Stater and Markee like this.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "So I ask again does the Prius have some kind of sensor light that lets you know when your brakes need replacement before you start cutting into rotor or is it just that wear indicator bar scraping sound ?"
    No.
  7. Markee
    Markee Member
    334
    Thanks for the advice where do you all think would be a good place to get a complete brake inspection other then the dealer ?
  8. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    In addition to the excellent replies thus far, bear in mind that your Prius uses regenerative braking so the pads will last much longer and wear much more slowly than those in other cars your mechanic may be accustomed to servicing. One other special thing you should know, if your master cylinder is pressurized like the one on my '12 Plug-in there is a procedure for relieving the pressure before even opening the cap. It's a job you may want to save for Toyota.
  9. Markee
    Markee Member
    334
  10. Mendel Leisk
    41,905
    Read through the attachment in post #5. Toyota's Repair Manuals are remiss, in that they show everything that can be done with the brake, but they don't spell out blow-by-blow what portion of that should be done at a brake inspection. Honda's better in that regard, their Shop Manuals have a definitive section titled Brake Inspection, and the same term is used in the schedule. From years with Honda, their manuals, personal experience, what I've seen at dealerships, this is what I'd see as a brake inspection:
    1. Lift the calipers off the rotors (brake lines still attached).
    2. Inspect and clean of the pads and shims, check thickness. Reassemble of pads and shims with proper lube in the faying surfaces (points of contact between components).
    3. Clean caliper, especially contact points with pads, inspect for cracks/damage. Lube the caliper points that contact the pads. Check brake lines for cracking/twisting/rust.
    4. Pull out caliper glide pins, clean and relube with proper lube, and lightly lube the boots as well. Reassemble.
    5. Check rotor thickness and runout against spec. Requires micrometer and dial indicator (with magnetic base). (I do sometimes goof off on this when DIY'ing, especially if I've done it before, everything was ok and there's no pulsing when using the brakes.)
    6. Reassemble everything and road-test.
    Lubes I use, neither kosher but no problems with either:
    1. Faying surfaces, pads to shims to caliper: Permatex Anti-Seize. (silver grease/paste)
    2. Caliper slide pins: Sil-Glyde Brake Lubricant. (transluscent grease, looks like Vaseline)
    If you were to DIY the Prius brakes, there are some specific, additional "gotchas" you have to be careful of, specifically:
    1. Precautions need to be taken to avoid the brakes "pressurizing" while the calipers are off the rotors.
    2. The integrated parking brake on rear caliper makes them a little tricky, you really need to get the piston orientation right (and make sure it STAYS right), to avoid brake drag problems down the road.
    #10 Mendel Leisk, Oct 4, 2018
    Bay Stater likes this.
  11. Markee
    Markee Member
    334
    Got the brakes rechecked and measured today back pads 6mm front are 3mm
    So looks like the fronts are ripe and ready for replacement
  12. JC91006
    16,827
    8,600
    49k miles and you're down to 3mm? Were your miles ever rolled back? People here don't usually need brakes until 100k miles....unless they get corroded. Very unusual for wear related.
  13. Markee
    Markee Member
    334
    I think it may have alot to do with my particular style of driving ?
    I use the vehicle for work purposes alot of stop and go local city driving going from business to business all day
    I'm a fire extinguisher service guy
  14. Mendel Leisk
    41,905
    The front's are relatively conventional. Whoever's doing it, a few tips:
    1. Disconnect 12 volt before any disassembly, and leave it off for the full duration of the work, when everything is reassembled, pump the brake pedal multiple times before reconnecting the 12 volt. This will ensure there's no pressurizing events while the calipers are off the rotors, and the car won't detect excess pedal travel.
    2. The front caliper piston is a high tech plastic: when pushing it back in use something that it's contact with the full diameter of the piston, avoid point loads.
  15. Markee
    Markee Member
    334
    I'm not going to do it myself the dealer seems to have a decent deal $109
    This would be the first time I'm bringing it to the dealer I try to avoid that hassle
    Anything else I should have them do or check while I'm there?
    about 49k miles on it now
    Raytheeagle and Mendel Leisk like this.
  16. Mendel Leisk
    41,905
    That's a very decent deal.
  17. JC91006
    16,827
    8,600
    $109 at the dealer is great, parts run $80+
  18. Mendel Leisk
    41,905
    Yeah I was thinking the same thing. I paid over $100 CDN at dealership for (2010 Prius) replacement rear pads. I checked McGeorge Toyota (online US retailer) and it was discount price $40, before shipping. Typically in Canada when going to a dealership, for brake job with pad replacement, I wouldn't get out of there under $200, front or rear. And that was maybe 20 years back, I just DIY now, unless it's something like a caliper rebuild (which I've never encountered).
  19. Markee
    Markee Member
    334
    They also have a $49.95 Service-Synthetic Oil change deal need that also good deal also
    Anything else I should have the dealer look at while I'm there ?
    Chances are I won't be going back there for a long time if ever
    #19 Markee, Oct 4, 2018
