Mechanic says they NEVER change transaxle fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Feb 23, 2019.
  1. CharlesPrius
    CharlesPrius Member
    154
    60
    My mechanic is great and they work on tons of Priuses/i - entire taxi fleets, and the owner owns 4-5 Prius/i himself. He says they never change the transaxle fluid. Is this stupid?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Yes;).
    While he may “work” on Prii that does not mean he knows anything about what he is working on :cool:.
    Might be time to find another mechanic (y).
  3. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    This has been discussed in many threads on PriusChat. Quite a few Prius enthusiasts feel that it is important to change the fluid or at least that it is worthwhile inexpensive preventive maintenance. Others, myself included, see no objective evidence of need to change it. Toyota calls it lifetime fluid. Search the forum for more comments. No need to re-ignite the debate.
  4. Mendel Leisk
    41,890
    For an hour's labour and about $40 for the Toyota ATF WS fluid and two washers, yeah I'd say it's "short-sighted". Up to you: these threads, and there's been many, the usual participants should all be along shortly: will drag on much longer than the time and effort to do the the chore.
  5. orenji
    orenji Senior Member
    5,887
    3,488
    Find a new Mechanic. I recently discussed lifetime fluid with a tech at a dealership, and I was advises that changing it out is smart! You have to remember lifetime for most manufactures is around 150,000 miles. So is the fliud lifetime, sure, but do you hope to have your car past 150,000 miles?
    RMB and Raytheeagle like this.
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    If it works, it ain't stupid. ;)
    Are there any reports of Prii needing to be scrapped because the transaxle failed due to not changing the fluid?
  7. Mendel Leisk
    41,890
    I can't see any problem with changing the fluid, with the proper spec'd fluid, once or twice through the car's life. There are stories of the original fluid coming out very thick and dark, which cannot be good.
    The one danger, DIY'rs think they can do better than the spec'd fluid, try alternates. Maybe they're even right, but this is not something I'd want to risk.
  8. audiodave
    audiodave Active Member
    800
    272
    US
    Just because the fryer keeps frying the fries doesn't make it ok to not change the fluid. Do you want it to work well or just work.
    BruceInOKC, Raytheeagle, RMB and 2 others like this.
  9. Mendel Leisk
    41,890
    That reminds me...
  10. royrose
    1,389
    953
    Foot of Pikes Peak
    To me, that's the bottom line:
    Evidence based:
    Clogged EGR cooler? Yup
    Head Gasket Failure? Yup
    Oil level dropping? Yup
    Hybrid battery eventually failing? Eventually Yup
    Transaxle failure? Where are the reports? Rare if at all!
    So, If it gives you peace of mind and feel that it's worth it, fine. But don't say or imply that others are negligent if they don't do it.
    I love the respectful conversations on PriusChat but we need something new to disagree on. I really hoped that my earlier reply, which I thought was even handed, would stop us from debating this all over again.
    Oh well.:sneaky:
    #10 royrose, Feb 25, 2019
  11. CharlesPrius
    CharlesPrius Member
    154
    60
    sorry i missed the 1st debate... my mechanic kind of laughed each time i asked him if they change transax fl
  12. bisco
    52,375
    There is no such thing as a reply that stops a debate, especially on the net, unless tidelands reply is the padlock.;)
    Raytheeagle and royrose like this.
