mechanical key does not work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simplifying, Aug 14, 2016.
  1. simplifying
    simplifying Junior Member
    33
    Lawrence, Kansas
    2006 Prius, I changed the batteries in both fobs and smart keys do not work. I tried both mechanical keys and both do not work.
    I am puzzled since the mechanical keys do fit into the slots, but neither will open the car.
  2. JC91006
    16,672
    8,518
    Either the key fob is not original to the car or the door is not original to the car. I would say it's more likely the key fobs are not original.
    #2 JC91006, Aug 14, 2016
  3. simplifying
    33
    Lawrence, Kansas
    The fob and mechanical keys both worked but just stopped working last night. Any other thoughts appreciated.
  4. JC91006
    16,672
    8,518
    can you start the car by using the key slot?
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Earlier this year, both my FOBs started getting flakey, and eventually I had to use the mechanical key, and it turned out to be the 12V Aux-Battery about to die. You might want to check yours just in case. The one in my 2009 Gen II had never been changed, and it was ~6 years old (which for a 12V battery is v. old!) - hope this helps - Wil
    BTW: Welcome to PriusChat! ;)
  6. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    Try some powdered graphite on the door locks. $ 3.00 at any auto parts place, Lowes, or maybe Walmart.
  7. simplifying
    33
    Lawrence, Kansas
    I cannot get inside the car at all.e arewt
  8. JC91006
    16,672
    8,518
    put the weak old batteries back in
  9. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    Will your car insurance pay for a lock smith to open the door ?
  10. simplifying
    33
    Lawrence, Kansas
    1. I tried the fobs and keys with the old batteries in to start with, I thought if I changed the batteries, it might open, but it did not.
    2. I will check with my car insurance. Good suggestion.
    Thankyou.
    co
    fr thatold b
  11. Patrick Wong
    18,200
    6,493
    How much rotational force are you exerting on the mechanical key to turn it in the slot? It may take substantial effort to unlock.
  12. simplifying
    33
    Lawrence, Kansas
    I gave it my best. I think I might gtry again with a hammer.....
  13. JC91006
    16,672
    8,518
    I would probably just try some wd-40 in the key slot first......then call AAA
  14. simplifying
    33
    Lawrence, Kansas
    Well, the hammer trriick did not work. I tried to turn the key with pliers and now my key has a lovedly little twist in iut.
  15. Patrick Wong
    18,200
    6,493
    Time to call a locksmith for help, then - before damage is caused to the mechanical lock. The locksmith can use a slim Jim tool to open the door.
  16. simplifying
    33
    Lawrence, Kansas
    Wd40 did not work.....
  17. JC91006
    16,672
    8,518
    do you have more than 1 prius in the family? are you sure you have the right key? I'm quite puzzled how everything stopped working
  18. simplifying
    33
    Lawrence, Kansas
    Will a slim jki
    No, just 1 Prius. The fob worked to open the door last night. Neither the fob nor the mechanical keys work this morning.Everything worked lastnight and yesterday.
    Will a slim jim work in this car if I tried it myselrf?
    mtsekf4
  19. JC91006
    16,672
    8,518
    Try to buy new batteries from a different location than where you purchased the last ones. That would be the easiest way to get back into the car, without damaging it.
  20. Patrick Wong
    18,200
    6,493
    Yes, if you know how to use that tool. You are trying to reach the horizontal rod that runs from the door lock at the door's edge to the door lock/unlock mechanical control near the front of the inner door panel.
