Mechanical lock broken
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anon_prius, Aug 17, 2019.
  1. anon_prius
    anon_prius Junior Member
    30
    I was working on my stereo last night in my 2011 with SKS and disconnected the 12V battery. I locked all of the doors manually overnight with the intention of using my mechanical key to get back into the car in the morning. Unfortunately my mechanical key is not working. It will turn 90 degrees both ways in the cylinder but it will not unlock the door. I can hear something thumping in the door when I turn it 90 degrees clockwise. I've twisted it so hard I broke the key off from the plastic fob. I'm turning it with pliers now since it cut my finger open.
    I think that the mechanical linkage between the cylinder and the lock must be broken. However, I can't find any information about this repair online. My plan is to call a locksmith in the morning so I can at least get back into the car.
    Does anyone have experience with this and what I should be looking for when I get the door panel off?
  2. ChapmanF
    15,610
    Your guess about the linkage sounds pretty likely.
    With luck, you might even find that one of the linkage rods has just popped out at the end. The ends are usually secured in little plastic combo grommet/retainers that you put the rod end through, then pivot around so the retainer part clips over the rod. If somebody forgot to do that last part, possibly the rod end just popped out.
  3. anon_prius
    30
    Just got back into the car with the help of a locksmith. After ballooning the passenger door and unlocking it he unlocked the driver's door from the inside and we had a look at it. He unscrewed the lock mechanism and pulled out the tumbler, fiddled with it a little bit and then stuck it back in the door and now it seems to be working. I'm pretty happy I don't need to take the door panel off today.
  4. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    How often did you use the mechanical key to unlock/lock the vehicle since ownership?
  5. anon_prius
    30
    Zero times, just purchased the car.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Its never been used or lubricated. Spray some lock lube in the key hole. Then go get a copy of that mechanical key and get a magnetic hide a key box and stick it under the car.
    Raytheeagle likes this.
  7. anon_prius
    30
    In panic this morning I hit it with about a gallon of WD40. After the locksmith fixed the tumbler it looks to be working properly now.
    Raytheeagle and edthefox5 like this.
  8. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Cool
    Over in the g2 forum so many posters never used there lock for years and years and then the 12 hour battery dies and they use the key for the first time and it’s rusted shut
  9. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Wd40 is not a lubricant, it’s a solvent. It will dry out quickly and you’ll be back to square one. Use a silicon, or lithium, or dry lube.
    edthefox5 likes this.
  10. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Contact cleaner the graphite.
