Mechanics: what are your most common tools?
Discussion in 'Gen 3 Prius Technical Discussion' started by PixelRogue, Sep 3, 2016.
Tags:
  1. PixelRogue
    317
    57
    US
    What are your most common tools when working on a prius? Specific sizes of sockets, wrenches etc.
    skorpyo33 likes this.
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Well, generally you get the best price buying sockets and wrenches in sets, but I believe you will find mid-range (6,8,10, 12 mm) the ones you use the most. In close quarters, a ratcheting wrench set is handy, as are socket extensions.
    A good repair manual for your model is a "tool" you will use again and again.
    As you start to put things back together, a torque wrench is a wise investment so that you can tighten things to specifications.
    Glad to hear others' suggestions!
    Valiant V and elementnomore like this.
  3. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    14 mm for oil changes.
  4. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    10mm for pretty much most other things//
    dyun1dyun1 and orenji like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    A multimeter
  6. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    Mostly the same Park bicycle tools used on my Cannondale bike.
  7. StarCaller
    1,246
    697
    don't want to forget this one/[​IMG]
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Techstream with mini VCI if we can add soft tools
    douglasjre likes this.
  9. Mendel Leisk
    38,729
    This is the bulk of the small stuff. Also, lots of funnels, syringes, graduates, hoses, floor jack, two sizes of safety stands (4 of each), four heavy rubber wheel chocks, drain pan, drain bottle with funnel, charger, jump pack, and on and on.
    Mr. F, ice9, Montgomery and 8 others like this.
  10. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The phone number to a REAL mechanic! :ROFLMAO:
  11. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    A 3/8" ratchet... but you need the tools for the job you're doing. Each time you do a procedure for the first time, you might need a new tool.
    Oil change? Toyota oil filter wrench
    Tranny oil change? A pump or a very long funnel with a tube, a beefy breaker bar and a special Hex socket that nobody has in their set. If you do spark plugs, you need a particular-sized plug socket, with the rubber insert.
    In general?
    A complete metric socket set with 1/4", 3/8", and 1/2" short and long sockets.
    A 3/8" and 1/2" breaker bars
    A set of extensions
    A set of metric wrenches
    A set of Allen wrenches
    A screwdriver set
    All kinds of pliers
    3/8" and 1/2" torque wrenches
    A box of rubber gloves
    Shop towels
    Clorox wipes
    A drain basin
    A rolling tool chest to store it
    A head mounted flashlight
    Floor Jack
    Jack stands
    You hopefully understand that one accumulates these over a period of years as various repairs require them. I would begin with the biggest Sears Craftsman toolset you can get -- like the $150+ set. Get one with the form-fitted storage case, because that way you'll easily account for all of your sockets when you're cleaning up.
  12. Mendel Leisk
    38,729
    Oh, and a pit lamp or two.
  13. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    If you are spatially challenged like most of us in suburbia and do not have room for a rolling chest ( I have a 2 car garage and park both cars in it), hanging them on the wall or the work bench works just fine. So add a hammer and a box of nails to the list;).
    I had a 3 car garage in Wichita, KS when we lived out there, but 2 tornadoes within a 1/2 mile of the house scared my wife away:eek:. I knew it was over when I saw she was looking for homes near her parents in the Bay Area :rolleyes:.
    I do miss the days of having a bay for working on the cars:(.
  14. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    I miss having a garage, period :(
    Montgomery, orenji and Rebound like this.
  15. Mendel Leisk
    38,729
    I gave up trying to stow all my hand tools in my (woefully small, single tray) tool chest, just lay them out on a work bench. More readily accessible that way anyhow. Some carpet samples help cushion them and keep sockets from rolling off.
  16. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    A 17 mm for removing the windshield wiper arms, if you want to change spark plugs.
    The tool to remove the oil filter cartridge, a scangauge2, ramps to run the front end up on and a jack for the rear to change oil, a good air gauge.
  17. Rebound
    3,964
    2,613
    Portland, OR
    Without further ado, I present, my tool chest:
    I printed the labels on one sheet of paper, cut them to size and affixed with cellophane tape. Simple, but it works:
    Electrical tools, bicycle tools, and a set of lonely feeler blades.
    Chisels and prying tools, lots of hex wrenches, and a bunch of unused nut drivers.
    Multimeter and various electrical leftovers
    Measuring tapes. Before I had this chest, I kept losing them and buying more.
    Pliers. Lots of pliers.
    Ratchets, breaker bars, extensions, and an oil filter wrench
    No, you can't have too many screwdrivers. No such thing.
    Metric sockets in all three drive sizes
    British sockets, including a Prius spark plug socket I made by jamming the rubber from a different socket into the smaller socket for Prius. Without the rubber insert, it's pretty hard to get the old spark plugs out. (Go ahead: Ask me how I know).
    Two torque wrenches, a drill, an impact wrench, lots of drill bits, etc.
    And there are two more drawers full of wrenches (one drawer) and hammers, but there's tons of miscellaneous junk in them and I'm just too embarrassed to show them.
  18. Rebound
    3,964
    2,613
    Portland, OR
    I'm thinking I need some kind of girlie picture on the wall to make it a real garage.
    skorpyo33, scona and Raytheeagle like this.
  19. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    @Rebound had a nice setup for a tool chest and probably garage as well:).
    I do not have room for one of those nice tool chests in the 2 car garage :(. see attached.
    With 2 cars in the garage, space is at a premium. But there is enough room for a hand made work bench and enough wood space to organize the tools. The wife also ends up using the bench for her projects:rolleyes:, leading to additional spatial constraints. The paint on the bench is from the trim replacements.....
    While nice to have a great tool chest, there are good things you can do without one:).
    ThePrius11 and Mendel Leisk like this.
  20. Rebound
    3,964
    2,613
    Portland, OR
    Our lives are so good...
