Meguiar's Headlight Protectant -- Good Idea? Bad idea? - Bleeh, who cares?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Apr 1, 2015.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    I have a bit of Amazon credit burning a hole....I am up to $30 on things I need....now I am looking for something to push me over the $35 mark for free shipping....
    Is this headlight stuff worth it? At the moment the lenses on the Prius are crystal clear.
  2. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    I use the Megiars headlight cleaner as mine are a little foggy. I think the. Protectant might make sense sort of like sunblock for your skin. But I skipped that so far.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    In my experience Meguiars makes good products.
    But also in my experience I've never needed headlight protectant or cleaner, my headlights have always stayed clear.
    Credit the environment? My normal cleaning procedures?
    I don't know? Maybe just luck.
    If your headlights are clear? I think I'd spend the money on something I knew for sure I would use or need. There's got to be a product you know and like?
  5. Patrick Wong
    18,200
    6,493
    Lika an oil or air filter, or windshield wiper blades, for example - if you want to purchase a car-related product.
  6. ETC(SS)
    6,958
    ^ concur.
    You know you'll need those.
    Put me down for a "Meeh." on the headlight treatment.
    GrumpyCabbie likes this.
  7. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I'm planning just to spray clear-coat on mine this spring.
  8. alekska
    alekska Active Member
    435
    138
    Atl
    I just did it. First sanded, then sprayed clearcoat. Looks good.
    - Alex
  9. cyberpriusII
    1,151
    1,701
    Mars Hotel
    So, four and a half years ago, I asked this question.
    Consensus seemed to be to do nothing. I always like THAT option.
    But, now the Prius lenses are cloudy and we have a new Subaru that has crystal clear lenses. I treated the Prius lenses about 14 months ago with MEGUIARS PLASTX and they came out great, but by the end of this summer, they are getting cloudy again.
    So, before winter sets in -- and while I can still move and bend -- I want to clean the Prius again and then, hopefully, is there any NEW ideas on what may keep them clear for more than a year or so, as well as protect the new Subaru headlights?
    kris
  10. Patrick Wong
    18,200
    6,493
    I suggest you clean the plastic, then spray a clear coat lacquer for UV protection. I would leave the new car headlights alone.
  11. Mendel Leisk
    40,586
    Not sure if it's new, but: keep the headlights out of sun exposure as much as possible. Clear out the garage clutter, use a carport or temp car shelter, park with the car pointed North (doesn't apply for @alanclarkeau), stuff like that.
    alanclarkeau likes this.
  12. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Most states require that you keep your headlight lenses clear (checked during state inspection). Over time they tend to fog up due to scratches from road debris and chemicals. Generic polishers work real well at polishing the plastic lenses, so I would imagine that Meguiar's would do just as well.
    #12 ice9, Sep 5, 2019
  13. pasadena_commut
    pasadena_commut Senior Member
    2,282
    679
    Southern California
    It is really easy to clear a set of headlights with sanding/polishing - and really hard to keep them clear. I used the Sylvania kit, which comes with a protective coating on a set of Civic headlights. After a couple of years they started to fog a bit, but it was different than the original problem. This time the problem was from a lot of tiny cracks and pits in that coating. Washing/stripping (just regular car wash detergent on the headlights, not necessary to do the whole car) and then waxing them cleared them each time. It held for several months at a time, a bit longer if it rained. Apparently the wax would also capture dirt and the rain would wash it off. The plastic underneath did not seem to be deteriorating from the UV. If it was that no amount of washing or waxing would have helped.
    Anyway, the amount of work to wash two headlights and wax them was very small. Maybe 5 minutes total every four months or so. I would have gone on like that indefinitely but that car had other problems so I sold it.
  14. Mendel Leisk
    40,586
    I wish they'd desist with the insane headlight "sculptures", get back to basic round headlights, in glass please. :cautious:
    Replacement costs are insane too. :mad:
    If glass isn't on, for whatever reason: basic and round please, and cheap/easy to replace. Having to pay a grand per side to get replacement for someone's styling exercise is a joke that's dragged on too long. :confused:
    #14 Mendel Leisk, Sep 6, 2019
    RRxing likes this.
  15. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Why make a mountain out of a mole hill? Most people wax their cars more frequently than they polish their lenses. I polish the lenses only as required, when I check brake lights and turn signals before state inspection. Polishing only takes a few minutes.
  16. Mendel Leisk
    40,586
    IIRC Owner'd Msnual says to NOT polish headlights. Not sure why; maybe polish will start to remove the UV coating, not sure. Still, maybe once deterioration starts, might as well?
  17. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Yes, polishing does remove the UV blocking layer. And Yes, eventually that layer is overwhelmed anyway and it’s worth doing a clearing treatment.
    And yes, all the clearing treatments are equivalent to each other, do whatever’s cheapest/easiest…
    The critical part is laying on another clearcoat at the end so you can buy some time against the next one. I’ve never found anything that works as well as whatever they’re doing at the factory. Rattlecans that work in the field seem to give 2-3 years of protection at the most, vs. 9-12 months untreated.
  18. pasadena_commut
    2,282
    679
    Southern California
    Polish by definition contains abrasives and it will damage the protective coating (if only a little at first).
    There is another problem I ran into. In the past I used to use PlastX on my taillights and headlights. The last time I used it after shaking it thoroughly it still had not mixed well, probably because the solids had dropped to the bottom and clumped somehow, no doubt aided by the furnace like conditions in my garage in the summer. So what came out of the tube had too much solvent on it and it immediately softened the coating on those headlights, with some of that coating peeling off. These headlights have not yet yellowed but those sections are doomed to do so long before the rest of the headlight does.
  19. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Forget all of those "mouse milks" and "elixirs" or miracle cures.
    I just installed a cheap $30 sun shade off of Amazon in front of my Prius v under the carport.
