Melted ABS Sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Terrell, Jul 1, 2015.
  1. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Yesterday morning, when starting my 2010 Prius, the red BRAKE light stayed on, and also the yellow Traction Control light and yellow ABS light. The brakes seemed less than usual. Dealer says the left rear caliper froze up, causing the ABS sensor to melt, causing the system to go into fail-safe mode (no regenerative braking).
    I have done no hard braking, the car is currently getting over 50 mpg, and has only 57,368 miles on it. I checked the brake fluid level, it looks fine. Also shut down and restarted several times, no change, lights still on.
    Have others seen anything like this? If the LR caliper was dragging enough to heat the rotor enough to melt the ABS sensor, why wouldn't I notice it dragging? What if I had been coming down the mountains in CO doing a lot of braking? (I live in Wisconsin where we have no mountains.)
    What would cause the caliper to freeze with so few miles? (Dealer says maybe rust. If so, this sounds like a bad design.) If one caliper did this, what about the others? Will they also need replacing? Does using the brakes so rarely allow it to rust up?
    #1 Terrell, Jul 1, 2015
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    Terrell - My guess...Wisconsin winters>>>road salt>>>rust 'frozen-dragging' caliper>>>very hot rotor>>>melted-cooked ABS Sensor.
    Terrell likes this.
  3. ChapmanF
    18,590
    The amount of power it takes to get a rotor really, really hot under a constant drag is a pretty small fraction of the power needed in driving the car, so you might not notice much really.
    I once did the brakes on my former vehicle and got tired of the bleeding process (looking back on it, I think the wheel cylinder seals were holding fluid just fine but admitting air on the return stroke, which apparently is a thing, and makes the usual pedal-pumping DIY bleeding method into an exercise in frustration, while a shop with a pressure bleed kit solves the problem completely in seconds), so I got it to Good Enough and then drove to a dealer and asked them to finish bleeding for me.
    When they came back out they said "we bled your brakes and we also adjusted your master cylinder pushrod, they should feel a lot better now" which was rather strange as I had just done the pushrod adjustment exactly per the manual and knew it was right, but I thanked them and drove home (couple miles). When I got out I could see the air shimmer around all four wheels. They had backed out the pushrod to the point the master cylinder never completely released.
    When I drove it back they had the temerity to tell me it was normal. "Yeah, the brakes on those trucks always get hot."
    To ice the cake, there was still air in the lines. I let the indy shop across the street from the dealer fix that, which they did with a pressure bleeder, in seconds flat.
    -Chap
    Terrell likes this.
    52,417
    ugh, another 2010 brake problem.:( o/p, i think it is a bad design, many more complaints on 2010's than newer. check out member 'mendel leisk' threads on rear brake lubrication. it does seem to have something to do with use, as fronts don't seem to fail. maybe the rear collects more snow and ice as well?
    Terrell likes this.
  5. Mendel Leisk
    41,951
    Have the brakes been opened up before, say by the dealership? The rear disc brakes have an incorporated parking brake. Every time you depress the parking brake pedal, a lever mounted on the rear caliper is rotated, activating a cam to slightly extend the piston, clamp onto the disc.
    The axle of this lever goes right through the cylinder back, into the piston. There's a clever spring wrapped around it, that only allows rotation in unscrewing direction. This accommodates reduction in brake pad thickness, over time.
    One issue though: whenever the parking brake lever rotates, the caliper piston might ALSO rotate. To prevent this, there's a cross pattern on the head of the piston, and a pin on the back of the pad, that's supposed to lock between the piston spokes. There's instruction in the Repair Manual, to ensure proper alignment of the pin between the piston spokes, during assembly.
    What I suspect is that just ensuring alignment of pin with cross pattern is insufficient. You also need to ensure the pad and piston face are well seated right after reassembly, by multiple presses of the brake pedal, before the parking brake is applied, or the piston may still rotate, the pin riding partially up onto spoke of the cross. If this happens, you get a grossly skewed pad, and lots of drag.
    Terrell likes this.
  6. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    [QUOTE="catgic, post: 2204117, member: 27147"]Terrell - My guess...Wisconsin winters>>>road salt>>>rust 'frozen-dragging' caliper>>>very hot rotor>>>melted-cooked ABS Sensor.[/QUOTE]
    Boooooo! :cry: So when the master mechanic tells me I probably should have the caliper replaced on both sides (assuming rust was the problem with the caliper sticking/freezing), then I should?
    Could it be that in a "normal" car, the brakes get used more, which keeps the rust down?
  7. bisco
    52,417
    yesyou may be able to save the other side with disassembly, cleaning and lubrication.
    #7 bisco, Jul 1, 2015
  8. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    No, none of the brakes have ever needed any repair before. I had to have the steering linkage replaced because the universal joint was going bad (covered entirely by warranty), but no other work has been done other than the recalls - one of which I think had to do with braking if I remember correctly - but I don't think it had anything to do with opening up the brakes, it had to do with a pressure assist cylinder I think.
  9. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Do you think a Toyota dealer would be willing to do that (disassembly, cleaning and lubrication), or will they just want to replace the caliper assembly? (My guess is that replacement is easier for them, makes them more money, and preserves liability.)
  10. bisco
    52,417
    agree. i would try to find a local mechanic. there is a service procedure for lubing the brakes. unless they're too far gone, the dealer should be willing.
  11. Mendel Leisk
    41,951
    I don't think Toyota mechanics are averse to routine caliper maintenance, ie: pad removal/check/cleanup, caliper pin relube and rotor inspection. This is normal duties.
    Caliper overhaul I'd think they don't do, it's more cost effective to use a refurb'ed.
    Terrell and bisco like this.
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    DO keep in mind labour rates are now -over- $100 per hour. In some places -way- over. It's much less expensive to replace rather than repair. It's also much "nicer" for the mechanic. If you've ever worked on old brakes you'll understand what I'm saying.
    Another possible cause for rear brake failure from corrosion is water in the brake fluid. It tends to accumulate at the calipers (heavier than the brake fluid so flows down to the bottom of the system). It does dissolve into the brake fluid, which is glycol based, but gravity rules, pulling it to the lowest point of the system.
    How does water get in? Past seals when parts move, a very small amount at a time. This is why it is recommended brake fluid be changed every two years or so. Water in the fluid lowers the fluid boiling point, and can be the cause of braking loss at extreme braking events (such as mountain pass descents).
    Not such a big issue with a Prius and regenerative braking, but the problem with a Prius is the brakes tend to be ignored, and that is a recipe for disaster.
    frodoz737 likes this.
  13. Mendel Leisk
    41,951
    Yeah, Toyota Canada's finally acknowledged brake fluid replacement is worthwhile. An excerpt from the 2014 Prius Scheduled Maintenance Guide:
    If the above-and-beyond chore you're referring to is caliper pin lube, that's a fast, trivial chore, if you've already got the caliper pulled off the mount for pad check and disk inspection. Replacing a caliper rather than do something like that would not make sense. If there's a problem with the piston, I think what they commonly do is pull replace the caliper with a previously pulled one that a specialty shop previously refurbished.
    #13 Mendel Leisk, Jul 2, 2015
  14. ChapmanF
    18,590
    There's something that puzzles me about rebuilding these calipers. If I look on, say, Village Toyota Parts, I can see a rebuild kit that includes the slide pin boots, piston boots and seals, just like the rebuild kit for any conventional caliper, but it doesn't say (or the illustration doesn't show) anything for the seals where the parking actuator goes through. I don't know how to buy those (if you can). Maybe it would be worth somebody asking at a dealer parts counter (and posting the answer, I'd be interested)?
    I'm sure it would be interesting to the group to post some disassembled closeups of the failed caliper to try to get some idea how bad it is. I have a bad feeling that even if the original cause was something else, enough heat to melt the ABS sensor probably also melted the piston boot, allowing road spray in and now the piston and bore will be rusty to some extent.
    -Chap
  15. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Here's an update to my original post:
    The dealer replaced the Left Rear ABS sensor, wire harness, caliper, wheel hub and bearing assembly (all damaged due to the heat), as well as the rotors and brake pads on both rear sides (left rear side due to heat damage, on the right side to be even). They also lubed the caliper slider pins (at my request, after reading about the problems here on Prius Chat - THANK YOU!).
    The dealer covered the $860.98 repair of the left side under Toyota Extra Care, as well as a loaner car for three days.
    I had to pay for the pads and rotors on both sides, because they are considered a "wear item."
    But the story doesn't end there...
    About a month later (8/12/15), I took the car back to the dealer, due to a low rumbling sound, which I thought might be a wheel bearing starting to wear out. They said it was the RR hub assembly, a $561.18 job. Since the car has only 58,383 miles on it, I asked whether that seemed "normal" for a bearing to wear out so quickly. They decided to let Toyota Extra Care cover that as well. Nice!
    So now I've had both rear wheel bearings replaced. I have owned many cars, but never have I had any trouble with the rear wheels. Is this a weakness of the 2010 Prius?
    One of the Toyota employees told me he worked other shops for years before coming to Toyota, and he has seen more brake problems on Toyotas than on other cars.
  16. Mendel Leisk
    41,951
    Overheating accelerated the bearing failure?
  17. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Evidently - get enough heat, I imagine the bearings don't like it - maybe the grease especially doesn't and the heat starts breaking it down. But I'm not an expert at all.
  18. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    When the overheating was on the left side and bearing failure was on the right?
  19. Mendel Leisk
    41,951
  20. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    See the details in my post earlier. :)
    The rusted slider pin led to the calipers not moving freely which led to dragging on the left rear wheel brakes, heating them so hot it melted the ABS sensor, damaged the bearing on the left rear side, which was replaced.
    Later the right rear bearing started to fail. I don't know why, but no, not from the heat of the left. I thought you were asking about the left side. Sorry if I was confusing by lumping two stories together.
