Featured Mercedes crashes two EVs
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Nov 1, 2023.
  1. bwilson4web
    15,524
    The energy in a collision is the velocity squared:
    For economic and engineering reasons, crash tests are into known barriers or run into by test carts. A cynic might suggests this is another way to reduce unsold inventory.
  2. bwilson4web
    15,524
    The energy in a collision is the velocity squared between the two:
    For economic and engineering reasons, crash tests are into known barriers or using well defined test carts. Regardless, dual vehicle, head-on crash tests can be entertaining:
    An earlier version:
    A cynic might suggest this was Mercedes reducing unsold inventory.
    CLUBGUY likes this.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I would perform a separate test to validate the automatic braking systems in order to avoid or lessen the actual impact. I can only assume that those systems were turned off for this test.
  4. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    That's just a 35mph head on crash... Once you get above 40mph you're on your own and they can't engineer your survival... So drive slower everyone! Be alert of everything around you and ready to react if something sudden happens is way easier if you're limiting your maximum speed.
  5. bisco
    49,490
    Lifetime average 22 mph
  6. Trollbait
    11,560
    Both cars are doing 35mph.
  7. Tideland Prius
    16,155
    Merged threads
    bwilson4web likes this.
  8. Roqu3
    Roqu3 Member
    Lima
    2019 Prius c
    go to 3.15 to see the crash
