message: key detected in vehicle
Discussion in 'Gen 3 Prius Technical Discussion' started by magnumrtawd, Mar 24, 2019.
  1. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    my wife travels with me often. she has her key in her purse for my car. we have had no problem in 4 years. Today the yellow triangle showed up and the message (
    message: key detected in vehicle) appeared. my 2010 operated as usual and the message disappeared then came back several times.
    51,154
    check the voltage of the fob batteries and 12v.
  3. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    It has not repeated so far. If it does I will check batteries. I'm afraid to ,Last time I replaced the key fob batt. it stopped working and cost me 200$.
    I'm running a test on the 12 volt. Its original and I test it every 6 mo. and it shows excellent health.:)
    51,154
    i have had computer bugs that don't repeat. toyota software is like microsoft
  5. Hammond_Egger
    Hammond_Egger Junior Member
    Delaware
    Check to see if your rear hatch is closed all the way. I had this issue for a day. Once I opened and shut the hatch it went away.
    It maybe a sensor loose back there as well.
