MESSED UP MY TIMING NEED HELP!!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stephano610, Jun 15, 2024.
  1. Stephano610
    Stephano610 New Member
    Ohio
    Long story short my I was doing HG on my 2014 ct200h(I figured ill get more help in this forum) and I messed up my timing. I took the chain off while the mark were not on the right spot (ill attach a photo) the only thing I aligned was the line in the camshaft with the bolt.
    So now how would I re align the timing from scratch
    (piston #1 and #4 are TDC which makes me think I removed the timing chain while piston#4 was compression instead of #1)
    PS camshaft probably moved freely as well now
