Metal Clanking Noise Coming From Left Front Tire Area
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BV3, Sep 18, 2019.
  1. BV3
    BV3 Junior Member
    Green Bay, WI
    Hello again PriusChat,
    So this issue has been going on for awhile and I thought that it was a usual noise for the Prius since it’s a hybrid. But after driving my ‘05 prius for 5,000 more miles after discovering the issue, the noise has gotten louder. The noise sounds like a metal gear rubbing up again something and it sounds even worse when driving straight like down a highway or down a road. It doesn’t make any noise when I brake or anything. I have a fear of my tires just falling off but I don’t want to get anything replaced until I find an answer. My left tire area is also making a dragging metal noise type but I don’t see anything dragging either. Do you guys know anything? My buddy thinks it’s the wheel bearing hubs but he’s not 100% sure. There’s also a missing brake dust guard on the right side as well.
    ***The first 5 photos are from the right side of the car. The last 4 photos are from the left side of the car.***
  2. JC91006
    16,768
    8,565
    Green Bay WI. Damn look at all that rust!
    It looks like it would be any part making that noise, axles, brakes, bearings......
    BV3 likes this.
  3. BV3
    BV3 Junior Member
    Green Bay, WI
    Lol I know! So much rust. But thanks for the advice. I couldn’t upload the videos on PriusChat so I uploaded them on YouTube. Here are the links!
    Raytheeagle likes this.
    51,925
    maybe a bad cv joint?
    great videos btw
    BV3 likes this.
  5. Mendel Leisk
    41,445
    I found brushed on "boiled linseed oil" nothing short of miraculous.
    BV3 likes this.
  6. BV3
    BV3 Junior Member
    Green Bay, WI
    Yeah I’ve heard of a bad CV joint. Will probably recommend that to a mechanic for advice when I see one soon. Thanks!
  7. oldtechaa
    oldtechaa Active Member
    336
    224
    NZ
    2013 Prius Alpha
    Also probably disgustingly smelly, especially when burned off by any hot or friction-affected parts. I can't speak about its effectiveness, though.
  8. Mendel Leisk
    41,445
    No smell when dry, slightly varnish-like smell when applying. Unless you apply with sprayer and get overspray on exhaust, no problems. Very durable too. I'll try to post a before/after pic tomorrow.
  9. Mendel Leisk
    41,445
    Right-rear corner, bottom connection of shock, and the metadata says April of 2015:
    Somewhere between then and now, at least 18 months back, I applied boiled linseed oil. A picture snapped this morning:
    #9 Mendel Leisk, Sep 19, 2019
    davecook89t likes this.
  10. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    It seems almost miraculous. Did you remove any of the surface rust with a wire brush or something? How can any product just make it disappear? None of the parts were replaced, right?
    [Edit] I just realized I used the exact same word you used.(y)
  11. Mendel Leisk
    41,445
    No wire brush. No parts change. Brushed off loose dirt/rust with a paint brush, a bit. I would assume the surface rust (a little more progressed) is still under there. But the linseed oil seals things good. I applied it with a foam brush.
    Edit: @tvpierce turned me on to this btw.
    #11 Mendel Leisk, Sep 19, 2019
    BV3 and davecook89t like this.
  12. bisco
    51,925
    when you seal the rust in, does it keep eating away?
  13. Mendel Leisk
    41,445
    I suspect not, starved of oxygen?
  14. bisco
    51,925
    interesting, thank you!
  15. BV3
    BV3 Junior Member
    Green Bay, WI
    Update:
    So I decided to replace my CV axles, wheel bearings, dust shields, brake pads and also my rotors. Now I don’t hear anything! Everything all runs smooth with no weird noises. Thanks for the input PriusChat.
    bisco and Mendel Leisk like this.
