Metal cranking noise when driving on dirt/rough road.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by peter3778, Apr 11, 2015.
  1. peter3778
    peter3778 New Member
    Guys,
    I just got a 2007 Prius and using it mostly on a dirt/rough road (Irvington/Jersey City - NJ). My problem is that there is a metal cranking noise coming from under car and trunk. This is nit happened when i drive on a good road.
    I already asked the mechanic to check sway bar, shocks, struts, and brake. They said everything is okay except the front left strut boots which is already worn out. But the strut itself is still in good condition.
    I'm OK everything except the noise. Already replaced new tires but it doesn't help. Any suggestions will be highly appreciated.
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Get the mechanic to go on a test ride with you.
    These cars are known to transmit a good bit of road noise to the cabin.
    If it does not do it on a smooth road, I don't think I'd worry about it too much.
    49,733
    you probably need bushings all around.
