Metal Flakes after Oil Change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AEA, Nov 5, 2021.
Tags:
  1. AEA
    AEA New Member
    Hello, I own a 2010 Prius with 138k Miles
    Previous oil change was at 130k miles. I changed my oil and noticed these metal flakes. I don't know the condition of the previous oil since I took it to a shop. Should I shorten my next oil change or is there any other measures I should take to maintain the health of my engine?
    Pictures should be attached below.
    Thanks!
    IMG_20211103_173820.jpg IMG_20211103_173833.jpg IMG_20211103_173845.jpg IMG_20211103_173859.jpg IMG_20211103_173919.jpg
    51,148
    5,000 mile change is always a good idea. are you burning any oil? blackstone labs can analyze the metal flakes.
    separately: are you aware of the egr issue?
  3. ASRDogman
    ASRDogman Senior Member
    7,235
    3,777
    Clean them off, and if they are aluminum color, I'd say there are parts of a bearing, or piston.
    You could be looking at a new, or used engine. Metal in the oil is never good. :(
  4. Mendel Leisk
    40,581
    How's it sounding?
  5. ETC(SS)
    6,956
    What do you know about this car's past?
    If this is your first oil change (that you did yourself,) then you're starting out with a blank slate.
    You can do some archeological record digging on the vehicle's maintenance records with your VIN.
    I also heard some talk in the past about looking up your engine S/N to see if it;s the one that was in the car when it left the factory.
    Personally?
    I do not really think all that matters very much.
    If your car is running well, not using or leaking oil, and getting good fuel efficiency I wouldn't lay awake at night worrying about it.
    If it's a middle-aged pound puppy, then you get what you get.
    A 12 year old Prius with 130,000 miles on the clock is not exactly a spring chicken, but there's no reason to expect that this car will not hold together for another 8 years and/or 100,000 miles.
    All you can do for NOW is to reduce your OCI to 5,000 miles, and monitor your oil burn rate and look for metal during the next oil change.
    Since it's still legal to do your own oil changes in the California, and you have access to relatively inexpensive 0w20 (>$3.5/qt) I would consider another change before 5,000 miles.
  6. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    I would be curious to see the the Blackstone analysis of your oil http://www.blackstone-labs.com
    Probably too late for this oil change but definitely the next one at 5K miles?
    #6 Paul E. Highway, Nov 5, 2021
  7. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    If there is metal chips in the oil it’s usually time to start planning farewells to engine. I would not plan long road trips.
    ASRDogman likes this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Those aren't metal flakes. Those look more like chunks. If I had something like that come out of my engine, the first thing I would wonder about is why it was still functioning. I would also clean the heck out of that pan, put the cheapest oil possible in the engine, run it for a few miles/minutes and drain it again to see if there was actually something still in the pan or if perhaps that contamination was from somewhere else. If that stuff actually came out of your engine, there's more in there and it will show up.
    If you're lucky, maybe its just something in the valvetrain failing. Any unusual noise?
  9. AEA
    AEA New Member
    Update after cleaning up the objects and dropping off the used oil. They particles seemed more like sand or dirt? One large chunk looked like a silica crystal and others were brown or black. It may have unsettled from the plastic protection cover while draining my oil and I have driven on dirt road in the rain somewhat recently. I will shorten my next oil change and see if the problem persist. Thanks yall!
  10. burrito
    burrito Active Member
    274
    114
    Did you cut open the filter to see if any of that stuff was in the filter? If the filter's clean, then that stuff wasn't in the engine.
  11. OptimusPriustus
    328
    137
    Finland
    :D I already wondered how come you had not noticed anything before oil change. Metal chips of that size coming out would be The end of story.
  12. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    To me, it looks like sand or grit. Could be the prior filter was faulty, or, they replaced it with a sub-par filter.
