Metal Key Code to find key Biting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mskozyigit, Feb 9, 2025.
  1. mskozyigit
    mskozyigit New Member
    Turkey
    Hello,
    I have 2012 Prius Plug in
    I create new key via Techstream software, but i wasnt make a new metal key, everything was good and it was happy days.
    and then I lost original metal key.
    now I open Driver side door lock to find keycode of metalic key, But it was not there.
    is anyone know where is the keycode of metalic door key in 2012 Prius ?
  2. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    I believe you have to open the door and there's either a special hole in the door frame or you take out a plug and you undo a threaded fitting and then the key part of your door handle will pull out if it's not like my generation too then you have to take the door panel off and you're taking the door lock cylinder out of the door and off of the handle from inside of the door frame of the car where the speakers are and the electric wiring and all that and when you withdraw the lock cylinder and have it in your hand you will see tiny little numbers on the lock cylinder I believe it's a four number code 3246 whatever it is that's the code that the locksmith needs and he'll have your key waiting when you arrive I do this all the time for the '04 to '09 for the 2010 to 16 or 15 I am not sure whether your handles disassemble on the car like mine in the earlier model If not then it's like a Corolla You take the door skin internally off and reach up inside of there with a 10 mm socket and a short extension and a handle and you remove the door handle this gives you access to the silver key cylinder with the numbers on it apparently if you're in the same market where the car was sold sometimes you can go to the dealer with your VIN number and your paperwork and they can figure out what that door lock code is without touching the car I'm not sure that a locksmith has this information but the dealer does The locksmith may actually have to get the door cylinder out of the handle to get the numbers to cut the key The dealer with proof may be able to do it with a VIN number but they charge you for that so it just depends on the route you want to go who cares about the key? I've never used mine yet unless I want to I haven't had to when I buy a new to me 04 to '09 that's one of the first tests I make I pulled the key out of the remote and make sure it works the driver door If it doesn't I know the key fob is probably a reprogrammed replacement that didn't go to the car and that's why the key doesn't work now I tell the guy well you need to knock $500 off for that and on to the next part of the list.
    mskozyigit likes this.
  3. mskozyigit
    Turkey
    Thanks for replay. I really appreciate that.
    it was the stuation for me. There was special hole side of the driver door. I open it and push the lock cylinder out.
    now I have lock cylinder. (y)
    there is some numbers, but for sure not Keycode :(
    I try everynumner on cylinder with Instacode Software but no result, even I try with Xhorse Dolphin 005 software, still no result.
    is that any guys out there maybe someone selling Keycode if you provide VIN number to them ?
    I ordered TOY48 Lishi Tool from aliexpres,
    When it arrived, i will try to figure it out with reverse coding :sneaky::sneaky:
  4. Mendel Leisk
    40,586
    @Tombukt2 are you essentially saying change the lock cylinder? It comes with matching key? That sounds sensible, and dealership parts department should be able to confirm.
    #4 Mendel Leisk, Feb 10, 2025
  5. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    I would contact a Toyota dealer.
    They have coding information for each car.
    Confirm that it is your car and they will provide the information to make a key.
  6. mskozyigit
    Turkey
    Thanks for replay.
    Yes it is best way but how much it will cost ?
    I can do same thing with lishi tool i hope
    Or some online guys selling key codes, but couldnt find any of them yet.
    Do u know any of these guys selling key codes for VIN number ?
    Otherwise i will wait 1-2 weeks and try to do it via lishi tool.
  7. bisco
    51,155
    I got a little metal tag with the fobs and a note: don’t lose this!
  8. ChapmanF
    17,349
    I didn't read the whole thing either, but he might just have been suggesting to read the code off the cylinder that's there and then get the key cut.
  9. Mendel Leisk
    40,586
    Yeah, in my notes:
    Key code tag: nnnnn (metal tag?)<<<<metal tag in Rose Tin
    key fob battery: Panasonic (or Energizer) CR 1632 (3 Volt)
    paint code: IF7 (Classic Silver Metallic)
    #9 Mendel Leisk, Feb 10, 2025
  10. mskozyigit
    Turkey
    he he :)
    I never had that.
    They didnt give it to me also when i got the car from the owner (secondhand)
    #10 mskozyigit, Feb 10, 2025
  11. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    I agree with Max, the dealer can look it up. I bought one from them for $35.
    There is a guy on ebay who will make one from a photo. Of course you need to have one first for this scenario.
  12. ChapmanF
    17,349
    That nnnnn wasn't your key code, was it?
    If it was, you can buy a new cylinder at the dealer that will have different bitting and two matching keys....
    Just put the new metal tag in the rose tin.
  13. mskozyigit
    Turkey
    If they ask 35 dollars then i can try that also. It was good to know indeed.
