metalic clunk when stopping in reverse from park
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusrc, Aug 4, 2014.
  1. priusrc
    priusrc Junior Member
    53
    lower pennisula, Michigan
    I read the other thread and I felt I shouldn't bring it from the grave.
    I only notice this when I back the car from the garage and come to a stop before going forward. It is a very metallic clunk. It sounds like its coming from the rear passenger side but I am. not 100% certain. It happens when I actually stop before switching to drive.
    It is a 2013 Two. 30,000 miles on it.
    49,446
    maybe take a look at your rear calipers and slide pins etc., just a wag.
    TsKarma likes this.
  3. AliPat
    AliPat Junior Member
    Are you seeing any computer codes? I'd get this checked out, as it sounds like the noise my 2005 made when the transmission failed. While trans failure is rare, it does happen. Your car is under warranty, so take it in for a check up. Better now than later, when you are stuck on the road.
    TsKarma likes this.
  4. priusrc
    53
    True, I guess I will have my mechanic look at both possibilities.
  5. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    mine has made a noise like your since it was new it is the brake pads moving around.
