Mevotech parts? Sway bar links, tie rods.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Higgins909, Nov 19, 2018.
  1. Higgins909
    Higgins909 Member
    277
    67
    I know the bushings on my sway bar links are shot (front sway bar to the struts) I'm not sure about the tie rods, but I should check them before I start to buy parts... Then I thought I needed new shock absorbers/dampers a while ago... Then I was wanting new tires/rims... One of the brakes are squealing, need to check that out too.
    But is Mevotech a good brand? Googling I've seen hit or miss. Is there another brand I should look into?
    Thanks,
    Higgins909
  2. Patrick Wong
    18,200
    6,493
    I would suggest you consider TRW as an aftermarket brand.
