MFD 2017 Prius (Touch Display)
Discussion in 'Gen 4 Prius Audio and Electronics' started by Haya, Nov 16, 2018.
  1. Haya
    Haya New Member
    Jordan
    Good evening,
    Is the display off or is it no longer working please? Because normally I should also be seeing the buttons (Audio and so on....)
    Thank you very much :)
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Have you tried pressing the PWR button at the bottom left? You might have to hold it in for a couple of seconds.
    krmcg likes this.
  3. Haya
    Haya New Member
    Jordan
    Thank you for your help! It seems that the fuse has burned out...Could this be caused by another more serious issue?
  4. StarmanUK
    StarmanUK Junior Member
    Essex, UK
    Business Ed. Plus
    If that doesn't work I'd be checking the fusebox in the glove box.
  5. bisco
    52,694
    how can we differentiate between off and not working?
  6. The Professor
    598
    809
    UK
    Excel
    If it turns on when you press the power button, it was just off. If it doesn't, something is not working. :D
    krmcg likes this.
