MFD - AUTOMATIC TURN OFF
Discussion in 'Gen 2 Prius Audio and Electronics' started by Capemayal, May 6, 2007.
  1. Capemayal
    Capemayal Junior Member
    26
    I know I've seen this somplace on the forum, but can't find it.
    When dsplaying the climate and audio screens, the display shuts off after several seconds.
    But, using the info and display screens, this does not happen.
    Is there a way to program the MFD to turn itself off for these screens?
    Thanks in advance
    Al
  2. Tideland Prius
    16,150
    Not that I'm aware. The climate and audio screen are programmed to revert the screen to the previous state (if you enabled it).
    Hence it'll revert back to the nav if that was your last screen. Since you had the MFD off, it'll revert back to the off position.
    I don't believe the DISP or INFO screen have that feature.
