MFD Died Suddenly
Discussion in 'Gen 2 Prius Technical Discussion' started by Daddybean, Jul 21, 2011.
  1. Daddybean
    Daddybean Junior Member
    West Palm Beach
    I have read all the posts related to MFD and touchscreen. Does anyone know a simple way to verify that in fact it's the MFD that needs replacing?
    2. Can I do a reset by pulling the ACC fuse (power source)?
    In W. Palm Beach, FL the dealer retail is $1,387 for the part. They want $100 to diagnose that goes toward the install.
    Thanks,
    Cameron
    PS Died while driving normally. Had low voltage issues the day prior while changing Aux battery.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Go see Josh Mellor up in Melbourne. I'll bet he can sort it out for you for cheaper. It is possible to repair the MFD, or replace it with salvage.
    mellor's automotive
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I do not know, but I had the idea that the MFD is powered by a 12V source. I would recheck the 12V voltage, the connections and try rebooting the 12V a couple of times. While the neg lead is disconnected from the chassis ground, disconnect the HV and reconnect, firmly pushing the orange handle in. Check for rust & or corrosion and tightness at 12V grd. point. All simple stuff. Next: Connective plug to MFD, not mating or corrosion. Florida does that!
  4. Daddybean
    West Palm Beach
    After driving approx 5 times, the MFD began working again. If YOU get a suddenly inop MFD after replacing the 12v aux battery, perhaps you should wait to repair in case it resets itself.
    Note: the MFD worked fine after replacing the aux battery, then suddenly died 2 days later.
  5. Patrick Wong
    18,200
    6,472
    I predict that you will experience another MFD failure soon, since the root cause appears to be a bad solder joint within.
