MFD on or Off, and will it affect life span?
Discussion in 'Gen 2 Prius Main Forum' started by Bill Lumbergh, Feb 8, 2006.
  1. MFD off, will last forever this way.
    0 vote(s)
    0.0%
  2. MFD off, but adjusting the volume and temperature will still cause it to die.
    0 vote(s)
    0.0%
  3. MFD on, how else will I track my mileage and see "where I'm going"? Will last a long time because i
    0 vote(s)
    0.0%
  4. MFD on, I'm gonna break it for sure due to continued use.
    0 vote(s)
    0.0%
  1. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    I personally leave the MFD off, as it's distractnig and I want to maximize its lifespan. How 'bout you?
  2. benighted
    benighted New Member
    530
    Westport, WA
    The LCD screen should last the life of the car without any problems.
    LCD technology doesn't suffer from burn-in as CRT and Plasma does. The most common failure to be expected with aging LCD's is "stuck" or "dead" pixels. This can happen wether you use the LCD screen or not because the liquid crystal still ages.
    The backlighting will also gradually dim, just like on any sort of display.
  3. DaveG
    DaveG Member
    806
    Vancouver, BC
    Well, the backlighting will eventually fail too, but the bulb in most LCD displays (at least as far as computer monitors go) is rated for around 60,000 hours, which is almost 7 years of being on 24 hrs a day, 365 days a year. Since most people don't drive their cars like this, it's not likely to be a problem :p
    If you drove your car for 4 hours a day, your screen would probably last somewhere in the range of 40 years - I'd be thinking about a new car before then :)
    Of course, the screens in the car may be manufactured to different standards, and certainly temperature variations have an effect, however it's probably nothing to worry about.
    Dave
  4. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    It's never even crossed my mind to turn it off to "save" it. It's part of the car and is made to be used.
  5. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    what other have said... it's 1) part of the fun of the car (and the FE game) and 2) it should outlast the car with the few hours/day it's in use
  6. Tideland Prius
    16,445
    I'd get a sunshade for the windshield. I'd be more worried about heat than screen usage. The screen and surroundings can get pretty darn hot in the summer.
  7. aaf709
    3,862
    2022 Prius Prime
    I normally leave it on. If it was a situation where I would be using the radio for a long time without being in "Ready" (at a drive-in movie, for example), I would turn the MFD off. But that would be to save power, not the screen.
  8. Walker1
    Walker1 Empire
    911
    FL
    I see no reason to not use it. I'm not worried about wearing it out.
  9. Walker1
    Walker1 Empire
    911
    FL
  10. daniel
    14,487
    1,519
    Spokane, WA
    Turn it off if you find it distracting. That's a safety issue. But if you turn it off to "save" it, what are you saving it for? To be able to make a television set out of it when the car dies, 250,000 miles from now? It's there to use. I'd rather have it die (if it's going to) when the car is old and nearly worn out, than not be able to use it now, and in ten years have an old junker with a perfectly-functioning MFD.
  11. chinook-hybrid
    chinook-hybrid New Member
    43
    South Sound, WA
    My wife and I leave it on, but, we opted for a screen protector. I bought it from sigma-automotive online. It doesn't interfere with the touch screen functions and is UV protected. Plus, you can't even tell it's there. Not bad for $12 IMO.
  12. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    Same here. I only turned it off once, and only to verify that it could be turned back on again by pressing any of the buttons around the display.
  13. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I've never turned it off to "save" it, but there was one time when I was driving on some really dark roads that I felt the need to turn it off to be able to see the road well.
