MFD "PROBLEM" beep and red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Aug 11, 2010.
  1. whodat
    whodat Member
    117
    Aptos, CA
    My 06 Prius with 130k miles just starting to briefly (1-2 seconds) show "PROBLEM" on the MFD and beep and sometimes show a red triangle.
    This only happens when I am going down hill on a tight curve when going fast. This never happens going up hill (since I am generally going slower) nor on flat roads. Since this is my normal commute road and I have not changed the way I drive for several years, I am surprised that this is now occuring.
    Some possible theories:
    oil is low - I will check
    some level sensor is complaining?
    some tire rotation sensor is complaining?
    Thoughts?
  2. Patrick Wong
    18,200
    6,471
    Low engine oil level is the most likely.
  3. whodat
    whodat Member
    117
    Aptos, CA
    Yes, you are correct. Engine oil was below the lower limit on the dip stick. I added 1.5 quarts to get near the top of the upper limit on the dip stick. Looks like I'm starting to burn some oil at 130k miles.
  4. uart
    uart Senior Member
    4,215
    1,200
    Australia
    1. How many miles have you done since the last oil change?
    2. Did you check the level on th dip-stick at the last change?
  5. whodat
    whodat Member
    117
    Aptos, CA
    Yes, the dip stick oil level was checked at the last oil change. The level was near the low mark.
  6. Patrick Wong
    18,200
    6,471
    I believe that the difference between the two dimples on the engine oil dipstick is 1.6 US quarts.
    If your practice is to add sufficient oil to reach the top dimple when you change oil, then it seems that your engine is consuming oil at the rate of at least 1.6 quarts over 8K miles, or 1 quart per 5K miles.
  7. jstack
    jstack New Member
    211
    38
    Chandler Arizona
    I
    My 05 did the red triange, kept making a high pitched beep and also put the car into netrual. At times it would repower and sometomes not. It also gave a screen warning of parking back button on and itermnittent while I drove. If I stoped and put the brake on and off it may clear for a 5 to 10 min period.
    Long story short, the system power up batteey was low again. I had just replaced it 2 weeks ago since it's an 05 with the original battery. Must be a charging problem in the DC-DC system ??
    You would think with all the displays and info it could warn, low aux battery. What a dumb system. Even an old car has a aux battery indicator, What up with Toyota anyway ?
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The cars display will tell you its static level as well as its charging level. It sounds like you have a serious drain somewhere. For procedure read 12V Aux Battery posts.
  9. andyprius
    2,212
    188
    No such system exist on any car battery system
  10. andyprius
    2,212
    188
    I notice that you have been thanked 33 times, so you are a pretty stable poster! My question is: Why did you initiate this thread?:D
