MFD with vertical lines
Discussion in 'Gen 2 Prius Audio and Electronics' started by VictorPrius09, Feb 5, 2025.
Tags:
  1. VictorPrius09
    VictorPrius09 New Member
    Virginia
    The MFD In my Prius had 7 buttons,
    4 on the left
    Display- no issue
    Info - no issue
    Climate - no issue
    Audio - no issue
    3 on the right
    Menu- nothing then times out to vertical lines
    Dest - same as above
    Map - same as above
    In fact the screen times out and defaults to the vertical lines.
    I'll attach pictures, any help is appreciated, suggestions to troubleshoot, etc.
    Many thanks.
  2. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    What is the condition of the connector from the navigation unit?
  3. vvillovv
    vvillovv Senior Member
    4,318
    1,498
    NY
