mg2
Discussion in 'Generation 1 Prius Discussion' started by shagpal, Apr 21, 2015.
  1. shagpal
    shagpal Junior Member
    this is a kinda crazy thought, but I did this kinda stuff with older vehicles.
    has anyone checked if a gen2 mg2 will fit in our gen1 transaxles? if it could physically fit, what are the possibility of actually making it work?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    This is idle speculation, but the Gen 1 battery is a different voltage than the Gen 2, so I suspect the windings on MG/2 are different as well
  3. ChapmanF
    15,461
    A lot changed, including the voltage it operates at. You're looking at easily a senior-thesis level of research and improvisation to get it to work, if that's what you're looking for (though a good thesis would start by explaining why this would be a good thing to do in the first place). :)
    -Chap
  4. shagpal
    isnt gen2 mg2 more powerful motor than gen1 mg2?
  5. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    I think if you are asking that question after Chap posted the above reply, you should stay well away from the idea you have put forward.
  6. shagpal
    no, I am just asking, not doing
  7. bwilson4web
    15,512
    My understanding is the NHW20 MG2 could be made into an electrically identical to NHW11 MG2 by rewiring the stator coils so some are parallel instead of series. Of course there may be mechanical fit issues that would have to be checked.
    Running the stator coils in series instead of parallel reduces the current but requires a higher voltage. In series, the (I**2)*R losses are significantly reduced.
    #7 bwilson4web, Apr 22, 2015
  8. shagpal
    #8 shagpal, Apr 22, 2015
  9. shagpal
    hi bob, are you referring to possibly rewiring something going to mg2, or rewinding coils within mg2?
  10. bwilson4web
    15,512
    Soldering the leads in parallel instead of series. No rewinding.
    #10 bwilson4web, Apr 22, 2015
  11. shagpal
    ok, as I understand it, the gen2 mg2 is rated 50kw, and the gen1 mg2 is 33kw.
    I know this is a stretch, but if soldering leads is feasible, would the power of the gen2 mg2 in theory change with such a modification, changing leads in parallel instead of in series?
  12. bwilson4web
    15,512
    Changing the internal stator wiring matches its load the NHW11 inverter that provides the voltage and current, the electrical power, to the modified MG2. The MG2 power is limited by the inverter electronics and traction battery.
  13. shagpal
    since such a hack would in theory yield no power gain, would their be a worthwhile gain in durability to consider?
  14. bwilson4web
    15,512
    We do not know but can speculate:
    • The NHW11 MG1 has suffered a number of stator burn-outs.
      • One SAE paper found that air bubbles entrapped in the stator potting compound of Japanese super trains can support coronal discharges that make ozone. The ozone eats the potting compound, insulation, and fails the motor. The paper discussed detecting the coronal discharge signature, microwave frequencies found on the power leads, to detect the pending failure.
    • Toyota made a number of manufacturing improvements that improved the quality.
      • UT Battelle papers analyzed the NHW20 improvements including dynamic testing.
      • Toyota SAE papers discussing the differences between the models.
    • Replacement parts
      • ~54,000 NHW11s -> ~44,000 today
      • ~700,000 NHW20s -> potential MG2 sources from crashed ones
