Mice and cedar oil
Discussion in 'Gen 3 Prius Main Forum' started by Tom G., Dec 10, 2012.
  1. Tom G.
    Tom G. Junior Member
    43
    Pelham NH
    I just got back from my 25,000 mile check-up, and the cabin filter was full of nutshells and chewed foam. I got the full $99 service to clean it out, and the dealer said that the best thing they had heard of to keep the little guys out is cedar oil.
    Has anyone had the same problem? What have you done?
    49,508
    thanks for the tip! many have had this problem and the only solution so far has been to cover all the openings with hardware cloth. what is cedar oil?
  3. ETC(SS)
    6,557
    Cedar oil???
    Hmmmm.
    I'm not so sure about that. Don't they put cedar shavings in hamster cages?
    Best thing I know to do is to keep a couple of hungry cats around.
    Failing that you could leave a few sticky traps under the car. Best of all....they're reusable!!!
    Just pull the mieces you catch off with a pair of pliers (sometimes their little feet will stay stuck in the trap, but that's OK) and you're ready to go again! :)
  4. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I read that peppermint oil helps. But maybe the first thing to try is putting those clothes dryer sheets in the openings but someplace that won't catch fire. There are other ways, like soda, but that probably won't help much in a car.
    Mike
  5. bisco
    49,508
    how about peppermint schnopz?:p
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Cedar is used in dog bedding not hamster bedding. :)
  7. Nightshaded
    Nightshaded Junior Member
    +1 Peppermint oil. I use it in our barn. No mice. Ground pepper works well also.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Cedar oil is toxic to humans. It won't kill you, it will lower your immunity to other pathogens. So I suspect it would be bad for the mice as well, repelling them. Peppermint oil might be a better choice. But then you'll have to deal with the children it attracts. ;)
    Many of those who have had mouse problems have used wire mesh over the openings (that they can find).
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
