  1. Myra d
    Myra d New Member
    San Anselmo
    My first prius had rodents and I thought it was a fluke. That cost $6,000! Then I traded it in and got a new prius and within 4 months it had mice. That cost over $10,000! One little wire was chewed and they had to replace all the circuitry. Thi is a prius issue. I have other cars over a 30 year period and not a single one of them has had mice. Two Prius within a year has mice!!!! This is outrageous. Its a scam. Theys ell a cheap car that gets great milage and then bring in the bucks big time with insurance claims because the mice are attracted to the priuses! How to stop this???
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    After all these forum post with mice problems, I will no longer be using a wireless mouse in my Prius....its touch pads only from now on!
    On a more serious note, if you search Prius Chat you will find some great post on this subject.
    I would lean towards the solution that coat the wire harness with a insulation/wire safe coating that mice dislike.
  3. Dion Kraft
    Dion Kraft Member
    272
    79
    Washington, UT
    Your going to adopt some stray cats and feed them near your car. The deal with mice is that they don't have collar bones so they can SQUEEEEZE into tight opening the size of their skull...thats their advantage. As for WHERE they enter. You have installed the mesh screen but that didn't do it so the recirculate door may be the entry point as another poster suggested.
    Someone going to have to chip in and say if they enter thru the screen (you installed) and then to the recirculate door?
    Or is the recirculate door seperate from the screens you had put in.
  4. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I have to believe there are some ways to stop the mice before they reach your car, and for far less than $10K. Look online, contact a professional exterminator, etc.
  5. bisco
    49,379
    if you don't have kids and pets, poison the heck out of the area with bait blocks.
    frodoz737 likes this.
  6. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    Where is the entry point? Mice getting to the cabin air filter can't be good. From there, they could chew through the air return cloth/filter and end up inside the car.
  7. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    Get a cat. Problem solved.
    Don't want to get a cat? Put an ad offering to house-sit for a cat. Keep the car near your car for a week or two. It will scent the area and the mice will stay away. There are organic methods like this which you can spray or scatter near your car which will frighten mice away.
  8. B. Roberts
    691
    211
    So I just have to tie a cat to the engine compartment so it will stay in there? No one knows the path mice take to get into the cabin air intake, then?
  9. bisco
    49,379
    aren't there some good threads here on closing up the entry points with mesh cloth?
  10. bisco
    49,379
    remind me not to move to san anselmo.:cool:
  11. Rebound
    3,964
    2,612
    Portland, OR
    No. The mere presence and scent of a cat in the area where the vehicle is parked should deter the mice.
    If mice are bedding inside your car, they may also be bedding inside your house's walls. Cats get rid of mice. It really does work.
  12. B. Roberts
    691
    211
    The ones I saw dealt with 2nd Gen mouse infiltration, not 3rd Gen.
  13. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    guess that's specific to cats/
    I have four dogs, every time I open a door on one of the cars they think they'll go for a ride & come & look inside the car (& probably leave some dog smell), every morning they pee on my tires - nevertheless I catch just under the prius on average like four mice a week....
    #13 StarCaller, Mar 7, 2016
  14. dk_brookdale
    dk_brookdale Junior Member
    63
    I am another Prius owner with rodents getting in to cabin air filter area. I have searched the engine area to find the entry point but have not located that. Does anyone know exactly where that entry point is?
  15. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    You have a rodent problem. Fix that first, then the car problem is fixed.
  16. Pseudonymm
    Pseudonymm New Member
    28
    The great northeast
    To block mice, remove the wipers and cowl and the metal tray with the dozen 10mm bolts. Then, on the passenger side you may see a large rectangular opening leading towards the glove box. That is where they get in and wreck your filter, or worse. Drill holes and screw down a sheet of fine metal screening. Also screen the opening of your air intake snorkel.
  17. farmecologist
    farmecologist Senior Member
    1,946
    1,785
    Southern MN
    I had a mouse problem over the winter. The damn things ate through my Clazzio car sear cover!
    Had my first Wth moment - Varmit ate thru seat cover! | PriusChat
    Entry was thru the cabin air intake and then into the glove box ( mouse poop evidence ) and then they ate into the seat cover. The theory is that the seat covers are 'organic vinyl' that the mice seem to like.
    Needless to say..this was my solution :
    No more mice. (y) I still need to do the intake blocking as mentioned above.
  18. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    How about the outlet openings in the rear?
  19. Pseudonymm
    28
    The great northeast
    There's the one next to the 12v battery in the rear that I know of. It does not look easy to screen, so I've ignored it. My screenings under the hood have been in response to damage caused--so far there hasn't been any evidence of activity in the back.
  20. bisco
    49,379
    ADC6287D-0510-49B4-A21D-B20F276046E9.jpeg Picture speaks for itself :(
    pjksr02 and Raytheeagle like this.
