Michelin Defender tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Pequeajim, Aug 11, 2012.
  1. Pequeajim
    Pequeajim Junior Member
    23
    New Holland, Pa
    I just put a new set of Michelin Defender tires on my Prius. They "feel" smoother than the stock tires, and are 8db quieter as measured on a sound meter. Not sure if there will be an improvement in mpg's, so I will report back after another tank or two.
    Nexus 7 ? 2
  2. DocC
    DocC New Member
    San Antonio, TX
    I can't wait to find out how they do. I'm considering them in the future.
  3. Pequeajim
    23
    New Holland, Pa
    So far, the they are running about the same mpgs
    DROID RAZR ? 2
  4. Roanoke Star
    Roanoke Star New Member
    Roanoke Va
    How do you like the ride and feel of the Defenders? How is FE?
  5. Pequeajim
    23
    New Holland, Pa
    They ride really well, but I have noticed that my mpg has gone down.
    Nexus 7 ? 2
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    The OEMs I have (Bridgestone Ecopias) are very noisy at higher speeds. My next set will be these no matter what they cost and no matter what the mileage trade-off is:
    Advantages and Disadvantages of the Michelin Primacy MXV4:
    About $123 each
    Very good tread life. With a 60,000 miles treadwear warranty.
    Low rolling resistance for good fuel economy.
    Impressive all-season performance in dry braking, wet braking, handling, and snow traction.
    Advantage: Compare to the Defender, it has better performance in producing less noise, better ride comfort, lower rolling resistance for better fuel economy, better snow traction.
    Disadvantage: Compare to the Defender, it costs about $6 more per tire, has slightly worse performance in the hydroplaning test, and has a worse tread life.
    Read more: Prius Gen III 2010 Needs New Tires | PriusChat
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Expect a pretty big hit in fuel economy with the Primacy MXV4. They are a good tire but that 3-4mpg loss stings. In the long run they cost a lot more to run than other quality tires out there.
  8. Addiesdaddy
    Addiesdaddy New Member
    I replaced the original tires on my 2010 Prius after 60K. I averaged about 63 mpg since car was new. my 80 miles a day commute is well suited to a Prius. With the defenders it has been about 57 mpg, I now have about 12K on the new tires. I don't mind the trade off for the otherwise all around better performing tires. But it is weird that I get better mileage with my snow tires (just put them on) than with the defenders...
    F8L likes this.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
