Michelin-Defender XT
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Sep 17, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    I ready to to a set of Michelin-defend XT, 90k miles warranty, and it LRR, what you guy think about these tires, welcome input:)
    V/r
    Khoi nguyen
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    It's a long life tire with great handling but some Prius drivers like to get better MPG. If you look at tire cost per mile including fuel costs, it is great tire, but if you want high MPG at the expense of higher tire cost there is Mich Energy Saver A/S. In other words the two tires are equivalent economics in the end.
  3. Pohaku
    Pohaku Member
    143
    23
    twin cities
    Put some on my 2010 last fall. Decent winter tire. Didn't seem to affect mileage appreciably. I've been getting @ 50 mpg this summer with them. No complaints. The oem tires wore pretty quick. I replaced them at @ 33k miles so I would have some winter traction.
  4. michinnom
    michinnom Member
    162
    29
    There are numerous posts on PC about the drop in mpg with the Defenders. I replaced my stock Yokos with Energy Saver A/S and am getting the same mpg as the Yokos. the ES has better ride, smoother, quieter, and handles better. I doubt the defenders really last 90k miles. You have to consider your own safety to rely on rubber for that long. Consider the effects of weather, including water, heat, cold, etc. which will all tear your tires apart over the years...marketing gimmicks like this one really ticks me off.
  5. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Michinom
    do you thinks Michelin marketing gimmicks?
  6. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Have about 15K on my Defenders and wear indicates 90K+ probable with 5-6 years use in my application. Achieved 40K wear on the OEM Yokos with proper maintenance, and those tires were horrible. YMMV, but wjtracy's evaluation is correct. But what do I know...;)
  7. VicVinegar
    VicVinegar Member
    264
    48
    Northern Virginia
    I owned a set of the predecessor to the Defender on a Civic and they were an 80k tires that gave me nearly that many miles.
    If it takes you 10 years to go 90k miles, you probably are pushing it on age and wont realize the benefits of the tire. If you drive 20k miles a year, different story. I also found them to be good in the winter and rain.
  8. zander
    zander Junior Member
    46
    connecticut
    They are great tires.
  9. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I'm about to order a set of these as well. I'm replacing a set of non-LLR Contis so I'm not expecting any real dip in overall MPG. I chose them because my local garage is very high on Michelin (Order from TireRack, they install) and I need a really tough tire up here (I never come close to the manufacturer's life expectancy on tires even with 5k mile rotations).
    I run dedicated winter tires so these look like a good 3-season toughie for my harsh, northern New England driving.
