Michelin Energy Saver A/S vs. Bridgestone Ecopia EP20
Discussion in 'Gen 3 Prius Fuel Economy' started by cary1952, Sep 28, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Anybody know the difference in mpg between these two tires?
  2. Mendel Leisk
    38,247
    Hmm, not a lot of responses, I'm interested too. Anyone care to revive an old thread, and experience with both?
  3. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    They should be close but I'd give the edge to the Energy Saver A/S.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Is the EP422 less efficient than the EP20 and why?
  5. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I can't answer that. I've never seen a test between the two. Bridgestone may be able to tell you. :)
  6. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Well I have owed Michelin, Assurance fuel max, Dunlap, Nokian and my best FE comes with the ep 20 tires . I really like them. H
  7. Mendel Leisk
    38,247
    Good to know, Harold. :)
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    You just made my decision for EP422 firmer.
  9. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Which michelin tire?
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
  11. HaroldW
    716
    95
    Energy Savers. H
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
  13. Mendel Leisk
    38,247
    Ep100 is summer tread I think. The first of Ecopia line? And maybe hard to find. Good RR though. You never see summer tire offerings up here, it's either all seasons or snows.
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    The EP100 was discontinued. It supposedly had better RR than the EP422 according to the director of the Ecopia line.
  15. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
    My problem has become that NOBODY has the Michelin Energy Savers in my area, whatsoever. Zero zip zilch. I give up. I was not going to get the Ecopia's because of a bad rep they have received on the site lately, but it might be my only LRR choice around these parts. o_O
  16. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    What bad rep?
  17. PriusGuy32
    1,411
    506
    Theres another thread going on the site thats pages long, with LRR tire discussion. I read through the whole damn thing (ugh!) and discovered that a few members had disappointing tread life, not as good mpg, and other complaints with the Ecopias, which once were the gold standard recommendation amongst members here. The consensus of the respondents (in that thread) was to convert over to the Energy Savers.
    #17 PriusGuy32, Nov 13, 2014
  18. Mendel Leisk
    38,247
    EP20 have been fine by us, on our ex Civic Hybrid. Good for LRR, tread wear decent, handling fine. They get noisy when worn, and are shite in snow once down to around 5/32" (not an issue if you have snows). Other than that...
  19. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    The most amount of snow I have experienced is a light coat of white dust on the pavement. ;)
  20. PriusGuy32
    1,411
    506
    I hate you.
