Michelin Primacy MXV4: Best Size Choice?
Discussion in 'Gen 2 Prius Main Forum' started by Aaron, Nov 25, 2012.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    My 2008 Prius has a stock tire size of 195/55/R16, however my choices in the Michelin Primacy MXV4 are 195/60/R15 and 205/55/R16. Which is a better choice? The 205 is listed as Low Rolling Resistance (H rated) on TireRack.com.
    Does it matter if I get H or V rated?
    I'm trying to decide between the Michelin Primacy and the Hankook Optimo H727
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Neither of those tires are very fuel efficient. The MXV4 is a much better tire overall than the H727 but expect a mpg hit vs. the OE tires. If handling is not a huge concern I would recommend staying with the OE size and use the Ecopia EP422. You'll maintain high mpg and comfort with an affordable tire. As a bonus the EP422 has great snow traction for an all-season tire.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    For fuel economy I would try to stick with the lowest speed rating. It seems like the higher you go the worse fuel economy you get. You don't need anything higher than a T in my opinion but H is acceptable. V should only be used if you are going with a 17" tire.
  4. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I saw the Ecopia EP422 ranked #9 in its catagory that's why I didn't consider it. I'm more concerned with wet/snow traction and willing to take a 1-2 MPG hit for that advantage.
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You're going to take a 3-4mpg hit with the other tires. The EP422 is better in snow than the MXV4 and offers better mpg than both of the other tires. CR ranked the EP422 low because of it's poor handling. The H727 handles poorly too. You have to decide which traits are more important to you. :)
  6. Aaron
    Aaron Member
    260
    Monroe, Ohio
    How is the road noise (highway)?
    The MXV4 that I'm looking at is rated as LRR. Would I still see a 3-4mpg hit on LRR?
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Close to it. Not all LRR tires are very fuel efficient. The Critic lost quite a bit when he put the MXV4 tires on his GenIII. They are a very good tire but I don't think they are very fuel efficient. If you don't mind a mpg hit I'd say go for it. They are a much better tire than the H727 and the Ecopia. :)
    Highway noise with the Ecopia is good as is the MXV4.
  8. turnbowm
    turnbowm Junior Member
    So. Calif.
    Do yourself a favor and checkout tirerack.com for owner surveys and test results on various tires. Based on owner surveys and Tirerack test results (link below), I went with Michelin Energy Saver for my wife's 2008 Prius Touring. I would recommend sticking with the OEM speed rating because tires with lower speed ratings have softer sidewalls and handling/steering response will suffer. Been there, done that!
    Tire Test Results : When Round and Black Becomes Lean and Green
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    They don't make that tire in the size he needs. The Energy Saver A/S is my favorite tire for efficiency and comfort. It's not made in enough sizes and it is not the greatest in snow/ice.
  10. Aaron
    Aaron Member
    260
    Monroe, Ohio
    The best price I could find locally for the Ecopia EP422 was $141 per tire out the door . Is that reasonable? Also, the tire sales guy recommended that I get an alignment ONLY at the Toyota dealer due to "unique" characteristics in aligning the Prius. Sound right?
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Yes. There was some discussion over this about 4 years ago. There was something not all alignment racks could handle. If the shop doesn't want to work on your car there's probably a pretty good reason behind it.
  12. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I figured. That's one reason I want to buy from this guy. His honesty about the alignment.
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If that is installed then it reasonable but not great. Unfortunately the only one running a discount on them right now is Costco.
  14. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Do you have to be a Costco member to purchase tires from Costco?
    DROID RAZR ? 2
  15. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Yes. Unless you have a friend with membership in there and charge his a/c and you pay him back.
    But later during the tire service,they need to see your membership card unless you op out the following : flat,rotation or balance... services.
  16. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I just had the local tire shop price match Costco. Now I got them for $114.50 per tire. $458 total out the door. I told him "I'll take'em".
  17. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Local tire place quoted me $110 per tire yesterday on the Ecopia +$14 mouting/balancing.
    Another place quoted me $140 out the door.
  18. turnbowm
    So. Calif.
    The Michelin Energy Saver is available in P195/55R16, but as a Summer tire and not A/S. This was not an issue for me since I live in So. Calif.
    2008 Toyota Prius Touring Tires | Michelin Tires
  19. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Those wouldn't make sense here in Ohio where it can go from 6o F and sunny to 28 F and snow on the ground in a matter of hours. We can't all live in the land of milk & honey!;)
  20. turnbowm
    So. Calif.
    Good point.
