Michelin X-Ice Xi3 Question
Discussion in 'Gen 3 Prius Fuel Economy' started by cary1952, Sep 24, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    What pressure should I run these at for winter driving for max fuel economy and decent comfort. I think they are rated at 51 psi.
  2. Slick26
    Slick26 Junior Member
    40
    Twin Cities, MN
    Generally speaking, in order for winter tires to be effective at what they were designed for, slightly lower pressure would be ideal, so they grab better. Too stiff and they won't be as effective. I'd say 35-40 would be sufficient. Anything more than 40 and you're kind of defeating the purpose. They're meant to be softer. Hope this helps.
  3. Bingee
    Bingee Member
    210
    62
    Michigan
    These are the snow tires I have .. Running 42 front 40 rear , did real well
    In west Michigan's first snow fall
  4. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I've running them 48/46. Temps in the 40's mostly. On my trip (on dry pavement) to Minnesota this week, as temperatures will drop into the teens and twenties, pressure will automatically drop lower anyway, and I won't have to mess with adding air.
  5. Slick26
    40
    Twin Cities, MN
    Travel safe to Minny. Weather looks good here. Chilly, but peaceful. Take care, and Happy Thanksgiving!
    Windows Phone ?
  6. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Averaged 45 mpg on trip. Temp mostly in 20's and 30s. Ran at 60-75 mph.
  7. Mendel Leisk
    40,575
    I've got our X-Ice2 at around 45 psi. They seem a little firm though, I may just let the expected dropping temps lower the pressure for me, a bit.
    (Oh, just noticed: you're using the same strategy, lol: letting falling temps do your work.)
