Micro question: oil filler cap sticks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chuckiechan, Jun 14, 2022.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Is the oil filler cap supposed to have a o-ring or rubber gasket? Mine seems to be plastic on metal and is very hard to get off.
    Thanks in advance!
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    nope /
    just the plastic cap /
    chuckiechan likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    It has a large 0-ring.
  4. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Hmmm….
  5. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  6. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I’ll put one on. Thanks.
  7. StarCaller
    1,271
    723
    yep, you're right /
    I looked at an old cap & it has an embedded O-ring /
    Mendel Leisk and chuckiechan like this.
  8. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    Nice picture; blown head gasket or just some moisture in your valve cover?? Looks a bit like milkshake.....
    Chuckie; don't forget to place a thin film of oil on that o-ring - It'll come off a lot easier next time. Use the same trick on your spin-on oil filters and cartridge filter caps. Makes oil changes a whole lot simpler.
  9. Mendel Leisk
    40,584
    Just a little segue: The spin-on filters I've bought (Toyota) have a clear plastic seal over the gasket end, and when pealed off there's an application of some sort of clear grease already applied to the gasket. Box still says to apply motor oil before installing, but that seems redundant to me.
    (And yeah, this is on a 2010, but I did the conversion to spin-on.)
  10. StarCaller
    1,271
    723
    Liqui Moly Cera Tec Friction Modifier
