Mid cycle refresh-What were the takeaways?
Discussion in 'Gen 3 Prius Main Forum' started by Munpot42, May 1, 2013.
  1. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    With the changes in the midcycle refresh some things that were standard in the 10-11 are no longer in the 12-13, the one thing I know is that the little tray in the center console is gone-what else was lost?
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Foglight blanks in the bumper cover. Now you have to buy the lower grill to add foglights.
    Silver painted alloy wheels.
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Stealth mode is gone.
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    No loss. First thing I removed when I bought my 2010.
  5. Tideland Prius
    16,445
    • The 2nd cupholder is exposed (previously, it was hidden in the centre console box so the box was larger and the 2nd cupholder was removeable)
    • POWER button is blue (previously black)
    • Hazard triangle button was black with red triangle. Now the entire button is red
    • Intelligent Parking Assist/Advanced Parking Guidance System was removed from the AT package (HUD was put in its place)
    • Leather is gone, replaced with SofTex in the Four, Five trim and on the Persona Series
    • DVD-based nav is replaced with flash-based 6.1" screen or HDD-based 7" high-res screen w/ split screen capability and DVD-playback
    • Water repellent front door glass was removed from Four and Give
    • Plasmacluster ionizer air filter removed from Four and Five models
    cwerdna likes this.
  6. Michael King
    Michael King Member
    72
    33
    Raynham, Massachusetts
    2018 Prius Prime
    Question on these two.
    Are both NAV's equiped with the DVD playback, or just the larger 7" one?
    I think the ionizer is standard now on the 2013's, right?
  7. Tideland Prius
    16,445
    Just the "Premium HDD Navigation" (so yes the 7").
    Nope. All gone.
  8. RaZa
    RaZa Member
    480
    93
    "Plasmacluster ionizer air filter removed from Four and Five models"
    I'm pretty sure mine has this. It has the button you can use for a 3 minute air cleaning type of thing. Pretty sure that's what you're talking about
  9. nklb
    nklb Member
    111
    No, the mode you are referring to just is a higher degree of air recirculation (cuts out even more outside air than plain recirulate mode) meant to pass more cabin air through the air filter.
  10. Tideland Prius
    16,445
    Nope. That's not the plasmacluster ionizer. The ionizer is a unit behind the driver's side vent that sends out positive and negative ions to attract dust and other particles and settle them down.
    The button you're referring to is a "dust & pollen filter" button (I know, it's confusing cause there's a dust and pollen filter behind the glovebox that is in use all the time). It closes the vents 100% (regular recirculation is about 70-80% closed) to pass cabin air through the filter.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The ionizer sounds pretty cool. Wonder why they dropped it...
  12. Tideland Prius
    16,445
    No value added to consumers?
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Sometimes you keep non-value parts just to brag about them. But the ionizer sounds useful if you know about it and how to use it. I had never even heard of it before. A bunch of dust gathers on my MFD.
  14. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Stealth mode is electric-only driving while still in HV mode, when that little "EV" symbol illuminates.
    That's been a fundamental part of the Prius system and still is.
  15. michinnom
    michinnom Member
    162
    29
    softex lol, pleather
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Maybe he means it's gone due to the addition of VPNS?
  17. car compulsive
    741
    274
    Michigan
    But now there's a noisemaker, so the stealth is gone and it's merely an EV with an electronic baseball card stuck in the spokes.
    Tim Powell likes this.
  18. john1701a
    12,797
    5,280
    57
    The engine remaining off hasn't changed. There has only been the introduction of noise at speeds up to 15 mph. Since Stealth operates at speeds up to 46 mph, "gone" is clearly not the appropriate term.
  19. Tideland Prius
    16,445
    Yeah but if consumers won't buy them, and it helps reduce cost, then the manufacturer would think so. I like the water-repellent front door glass on mine (removed in 2012). Works well in the rain and snow.
