Mild Chirping Noise at Highway Speeds
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by sufyant, Mar 14, 2025.
  1. sufyant
    sufyant Junior Member
    38
    2024 Prius Prime
    XSE Premium
    I am having faint chirping noise from driver side window at highway speeds greater than 65 MPH. The chirping noise becomes faster and slightly louder as speed increases. Any ideas?
  2. Trollbait
    12,310
    High pitched? Sort of an intermittent screech? Could be the brake dust shield rubbing against the wheel.
  3. sufyant
    38
    2024 Prius Prime
    XSE Premium
    I would say medium pitched just like birds chirping and yes intermittent.
  4. vvillovv
    vvillovv Senior Member
    4,318
    1,498
    NY
    With engine running ? Without engine running in EV? How much above 65 mph, not saying you should check this if not comfortable with it, does it stop at 80 or 84 mph in EV (without engine running) or with engine running. Just a couple of Gen 4 Prime related programming thresholds I'd check if I was hearing a weird noise only at hwy speeds.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    Time to check your brake pads...
  6. vvillovv
    4,318
    1,498
    NY
    This new post reminded me of another possibility of loose underpanel(s) and missing pins.
    I had the issue once at hwy speed nearer the end of a 400 mile trip that was loud enough to scared me, thinking it was something more serious than it a few missing pins on the passenger side front fender liner.
    Found a loose panel this morning - was something stolen? | PriusChat
    #6 vvillovv, Mar 17, 2025
